Can A Looper Pedal Do This?
Discussion in 'The Stomp Box' started by Steve 78, Mar 23, 2016.
Tags:
  1. Steve 78
    Steve 78 Friend of Leo's
    Melbourne, Austraila
    My current band (still in the embryonic stage) will use a drum machine so we know the exact BPM for each song ahead of time.
    What I want to do is something like this, for a live performance:
    - Play and record a verse rhythm part.
    - Loop it and play the verse lead part over it.
    - Turn it off during the chorus.
    - Start the loop again during the next verse and again play the lead line over it 'live'.
    So I understand I need a looper with quantize to do this. Does the quantize stretch the recorded loop or just make the loop length end at the closest beat/bar? I don't really want anything stretched.
    Is it possible to preset the loop BPM and length so it will end the recording automatically?
    I think starting the loop off with a manual switch will be accurate enough, but is there the option of switching using an external clock signal? (MIDI controlled perhaps?)
    Can I record multiple separate loops which can then be triggered separately or together? How many? If I recall correctly, some loopers allow you to overdub the loops as many times as you like with the option of switching the last overdub on/off. Is there anything more powerful than this?
    Thanks for your help!
  2. erratick
    erratick Tele-Holic
    SoCal
    You can get looper pedals that will do the 4 items you bullet pointed. You (and anyone playing with you) will have to have impeccable timing even if you have quantized loopers. You don't need a quantized looper, but it may make it a little easier.
    I feel like I have good time, but when I started using a very simple looper (TC ditto) I had to tighten up. There was also a little learning curve with the looper, but they are all like that I expect.
  3. DaveKS
    DaveKS Friend of Leo's
    KS
    What you need is midi clock sync to drum machine. I believe Pigtronixs Infinity Looper has all features you need.
    New Ditto X4 also has 2 loops and midi now.
  4. Steve 78
    Thanks guys. I'm definitely expecting a learning curve as far as timing goes. It looks like the midi clock sync is the way to go. Infinity and Ditto X4 both look good - I'll have to try them out. Cheers!
  5. DaveKS
    KS
    Here is a new product that allows you to sync a Digitech Jamman with jamsync with midi clock, very cool.
    http://www.customliveelectronics.co...s/24-syncman-jamman-synchronisation-midi-korg
  6. popthree
    popthree Poster Extraordinaire
    a hawk makin lazy circles
    boomerang 3 will also sync to midi. you would have to play the verse live/create the loop live as the rang doesn't do stored recordings.. but isn't that what a computer is for anyway?
  7. Steve 78
    Exactly, I am going to run some pre-recorded drums and keys via computer but I want to keep the guitars as live as possible, hence the live looping. Cheers.
  8. valvestate
    valvestate Tele-Afflicted
    Land of the Merlion
    Just with my own experience, playing a looper in a live band is a disaster, not unless you have an extremely good timing and in tight lock with the BPM.... but since you will be using some Midi, it might work for you.
