Caline Golden Halo acoustic simulator
Discussion in 'The Stomp Box' started by bigbean, Nov 13, 2019.
  1. bigbean
    bigbean Tele-Afflicted Ad Free Member
    Hartville OH
    I picked one up to use so I didn't have to bring an acoustic for just one song. It works pretty well. No tone suck off of the rest of my board. Transparent when off. I like it a little better with single coils than buckers but it's OK with buckers.
    bcorig and Switchy like this.
  2. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    Happy NPD.
    I wonder if it's a clone of the Boss Acoustic Simulator?
  3. telel6s
    telel6s Tele-Afflicted
    Northern Virginia
    What are you running this into? An electric guitar amp, acoustic amp, powered speaker or mixing board?
    Ages ago I had the first BOSS acoustic sim. I would put the effected output to the non-reverb channel on my Super Reverb so I could set the tone and level separate from my electric guitar on the main channel. I can't say it fooled anyone into thinking there was an acoustic guitar on stage, but it was a semi-useful sound for playing rhythm in a band with another guitar player.
    I also have one of the older Zoom acoustic effects pedals that can be used as a simulator for an electric guitar input. Into a regular tube amp it's worthless to me even though it has settings for defining the type of amp (combo, stack, etc.). But I have used it with a Tele once in a while as a backup for acoustic gigs like farmers markets. It does OK in that type of setting. Again, nobody is fooled into hearing a real acoustic guitar but it adds some nice ambiance - although I always have reverb/delay/chorus/etc at a greater level than with a true acoustic guitar. But, that became just one more thing I'd have to bring to a gig so it stays at home (should go on eBay/craigslist but I'm too lazy).
    So, a simple, cheap pedal like this could be useful as a back up to me. Or as the weather gets cold I'd rather not bring out the acoustic guitars and could just use a solid body electric which will be more stable.
    As an aside, 90% of youtube videos for this and other acoustic sims are poopoo since they run them into guitar amps, sometimes overdriven (I'm talking to you In The Blues!), without also showing these through a PA or acoustic amp.
    bcorig likes this.
  4. vanr
    vanr Tele-Afflicted
    AZ
    Wow. I bought one of these about a month ago and couldn't return it to amazon fast enough. Maybe I got a bad one. Actually 2 bad ones as the first one I received didn't work.
  5. bigbean
    Hartville OH
    I am a pedal board player with this rig. The board feeds an Allen&Heath GLD with some compression and a gate. The pedal is in front of the Timmy when used, the only thing between the pedal and the Aphex DI is the verb. It sounded OK when I tried the vibrato with it but I’m not using it with that for this week.
  6. Switchy
    Switchy TDPRI Member
    Arizona
    I bought one of these Golden Halos and I actually like it, for the price. The STANDARD setting seems to be the best and you have to find the sweet spot for the body and top knobs. I acknowledge that the Boss has some better tones, but I wouldn't buy the Boss unless I could get a real good deal on it.
  7. bcorig
    bcorig Tele-Afflicted Silver Supporter
    Chino Hills CA
    I have an “Old Zoom acoustics effects pedal” I bought 15-20 years ago and have never been able to figure out, for the Life Of Me, how to use it.
  8. Larry F
    Iowa City, IA
    What is the design theory, or whatever it's called, of these acoustic sim pedals? What do they do to an electric guitar input? OD, I get, same with reverb, delay, phasing, and whatnot. I have a fairly good mental representation of what these pedals to do the sound. But how does an acoustic sim pedal, such as the ones discussed above, actually change the sound?
  9. telel6s
    Northern Virginia
    Is it the green A2? That's what I have. For the longest time I had no clue how to really use it. Last winter I pulled it and the manual out and worked my way through it. I had to set up an excel spreadsheet to keep track of my patches and settings. Not intuitive.
    Eventually I got a couple patches I could use with acoustic guitar or my Tele (with the sim). OL for open mic night but that's about it. The hardest part I found was you can't easily turn off any one part of the chain. You can set to zero, but not get rid of comp, delay, mod, guitar model, etc. Makes each patch a pain to create or modify.
  10. bondoman
    bondoman Tele-Meister
    vallejo ca
    Ya know I've always been a bit wary of these peddles for one reason or the other. I also have no issues with bringing an acoustic to a gig either. Although I did cross over to the dark side many years ago, being guitar synths. In which case can emulate just about any instrument known to man and then some with just one guitar. Is it practical? No. Is it fun? Absolutely! Basically just another piece of gear haul, plug into and navigate your way thru. Easier to just bring an acoustic. Now if you want to remind the bass or keyboard player they can be replaced the guitar synth is a great tool.
  11. bigbean
    Hartville OH
    Seems to me it's mostly EQ and harmonic manipulation. I've got a Roland (Boss) Cube 40xl with an acoustic simulator as a setting. To me that sounds more digital synthy than the Caline pedal, also more compressed. The general idea is you put in an electric guitar in and get out a signal that sounds like a an acoustic with pickup in it.
    Obviously, it's not for everyone but I was surprised how good it was for very low buckage.
