Cabronita body identification
Discussion in 'Tele-Technical' started by Mike Simpson, Mar 9, 2017.
  1. Mike Simpson
    Gilbert, AZ (PHX)
    I bought a cabronita body and I am trying to figure out its origin. Thanks for any help. The Seller said it was MIM, I was mostly buying it for the pickups but I went ahead and bought the loaded body.
    It has micro tilt in the neck pocket, I don't see this on MIM and Squier bodies.
    The bridge has the 2 forward screws normally seen on Squires.
    There is a bunch of stamps in the neck pocket and 2 bar code stickers in the bridge pickup route. C00817938 and C00854130
  2. robinn
    robinn Tele-Meister
    Belgium
    The most obvious identification I think would be the bridge, and that one is indeed the squire one. The mexican bridge has the 3 mounting in the center of the bridge. Maybe make sure what's underneath it?
    The squier carbronita is basswood, but I don't know how to recognize that from the neck pocket.
    Dismalhead likes this.
  3. Tuxedo Poly
    Tuxedo Poly Friend of Leo's
    Merseyside UK
    The microtilt looks original which would suggest a 2011 'Tele-bration' series US made Cabronita.
    Curious.
  4. Mike Simpson
    Gilbert, AZ (PHX)
    Here is s pic with the bridge removed. Interesting that there are 3 bridge screw pilot holes near the string through holes.
    As I noted earlier, I was buying this for the TV Jones Powertrons and the body was part of the package deal. I doubt the body is basswood, I suspect ash or alder by the weight... not light but not super heavy but I have not weighed it yet.
  5. bender66
    on my bike
    You'd know whether it was alder or basswood just by the weight.
    I think tux-poly nailed the id on it.
    You get it for a good price?
  6. Mike Simpson
    Gilbert, AZ (PHX)
    So does it appear to be a US Telebration body that had a cheap bridge put on it?
    Ya, in my opinion the price was good... $200 for the body and a pair of TV Jones Powertrons. I have the neck plate, switch, pot and knob that are not on the body.
    bender66 likes this.
  7. Mike Simpson
    Gilbert, AZ (PHX)
    Is there a site I can look up the bar code sticker numbers?
    I googled around and I couldn't find much on them.
  8. Tuxedo Poly
    Merseyside UK
    The original neck plate would be a special engraved one and the pickups were filter'trons not power'trons. The bridge screw holes are correct for the US hardtail bridge. $200 is a great price.
    Fender may be able to help confirm id from the codes on the stickers and the neck pocket stamps.
    Mike Simpson likes this.
  9. Mike Simpson
    Gilbert, AZ (PHX)
    These pickups have the TV Jones Powertron sticker on the back. I checked them with a meter before I bought them and they are very close to the resistance listed on the TV Jones site for Powertrons. I built a Cab style in 2014 that has 3 TV Jones Classics in it and I bought these to give the Powertrons a try. I will probably just make a neck for this and buy a better bridge.
  10. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    I'm not familiar with the micro tilt, but I thought there was a metal plate in the neck pocket, not a simple T-nut?
    Check under the pickguard, IIRC, my Squier Cab had [EDIT] routing which prevented me from going guard-less.
  11. Mike Simpson
    Gilbert, AZ (PHX)
    The metal plate goes on the bottom of the heel on the neck. There is a setscrew that goes in the T nut and there is a hole in the neck plate to adjust it through.
    BorderRadio likes this.
  12. Mike Simpson
    Gilbert, AZ (PHX)
    I'll pull the pickguard off tonight to see if there are any surprises there.
  13. Mike Simpson
    Gilbert, AZ (PHX)
    Under the pick guard there is a crop circle to match the one in the neck pocket.
  14. Mike Simpson
    Gilbert, AZ (PHX)
    I decided to make a neck for this body.
    17436188_10155024385684651_8307944716803970000_o.jpg 17634725_10155039953274651_5729851888327328207_n.jpg 17629891_10155039953279651_6292449716187810145_n.jpg 17626640_10155039953289651_36148651466256072_n.jpg 17629612_10155039996069651_7083791031743423061_n.jpg
    robinn and BorderRadio like this.
  15. Mike Simpson
    Gilbert, AZ (PHX)
    17637045_10155040126004651_5269711361524538397_o.jpg 17757431_10155040107179651_1304208722867155956_n.jpg 17629710_10155040101169651_2611757952938047741_n.jpg 17426281_10155040052019651_5644372482378541893_n.jpg
  16. Mike Simpson
    Gilbert, AZ (PHX)
    17629631_10155040505799651_7105943219644567255_n.jpg 17757277_10155040505794651_103926782549086526_n.jpg 17630143_10155040505789651_4600007088894696593_n.jpg 17632378_10155040192079651_2166562624028363306_o.jpg
  17. Mike Simpson
    Gilbert, AZ (PHX)
    17499482_10155042732494651_8535608014383734339_n.jpg 17620225_10155042708284651_8589725867853518304_o.jpg 17620229_10155042707109651_8487225302375526959_o.jpg 17757331_10155042703214651_5741180863445618620_n.jpg
  18. Mike Simpson
    Gilbert, AZ (PHX)
    17637000_10155042854804651_5460968573210515010_o.jpg 17620336_10155042839994651_4523422120150950990_o.jpg 17553458_10155042753289651_1547926638481751921_n.jpg 17634550_10155042753309651_227806912898949309_n.jpg
  19. Mike Simpson
    Gilbert, AZ (PHX)
    17757422_10155066305959651_4400771245004226717_n.jpg 17759942_10155066305954651_7096779336628832036_n.jpg 17861984_10155066305949651_2104146468256729815_n.jpg 17637194_10155043645209651_3008952566452605486_o.jpg
  20. Mike Simpson
    Gilbert, AZ (PHX)
    17854825_10155066762544651_6390150571512737118_o.jpg 17884035_10155066560154651_4559445491424690735_n.jpg 17861585_10155066560149651_5752901390438482977_n.jpg 17798963_10155066305964651_2976616127063782168_n.jpg
