butterscotch from water-based stain?
  • Thread starter Jimmy C
Jimmy C
Michigan
I'm starting a pinecaster and I want to finish it with tru-oil. I'd like it to have a hint of butterscotch blonde, though. I've read that water-based stain is best under oil finishes, but does anyone have advice on what brand and/or color I should look for? Any tips on application are welcome--this is my first project. Thanks!
Colt W. Knight
Garland, Maine
Its pretty tough to dye/stain pine evenly. I would actually recommend trying some amber shellac instead.
Stratified
Maryland
Check here for Minwax stain color combo for butterscotch:
http://www.tdpri.com/forum/telecast...6259-blackguard-partscaster-project-pics.html
There is a pic of the three open minwax cans, but it appears the pic of the finished guitar is gone. There seems to be a pic of someone else's guitar that used the same recipe. Personally, I think the shade is a little intense for me, but I bet it could be adjusted without to much difficulty. However, it has a lacquer top coat.
(Besides trying on scrap) you might consider spraying the water stain with a preval sprayer.
Here is another thread with minwax water stain rubbed on, followed by tru oil:
http://www.tdpri.com/forum/telecaster-discussion-forum/53011-tele-project-finally-done.html
It's not butterscotch, but minwax followed by tru oil seems to work.
NOTE: neither of the links I've provided deal with pine. Colt's warning re staining/dying pine should not be taken lightly.
Some strategies you might investigate for pine is a wash coat of shellac to prevent uneven staining, pre-stain conditioner (similar to the shellac wash coat, but a thinned poly is what I hear is the content), or spraying the stain. Practicing with any of those options would be wise.
flyingbanana
Southern, California
Hi. Welcome to the forum.
Find an oil soluble dye or tint and mix up the appropriate ratios of colors to achieve a milky concentration when mixed with Tru Oil. If you can find some methoxylated alcohol, it will make this mixing job easier.
Jimmy C
Michigan
Thanks for the warning, Colt. You've got me rethinking things. Maybe I'll coiunt on the tru-oil to add enough color (?) If I go the shellac route, will the tru-oil still penetrate?
Jimmy C
Michigan
Thanks for the links and the suggestions, Stratified. I'm glad I joined this forum...
Jimmy C
Michigan
Thank you, flyingbanana. Is methoxylated alc like denatured alc?
allen082
fort worth
+1
this was the method I used for my pine build.
Colt W. Knight
Garland, Maine
Thanks for the warning, Colt. You've got me rethinking things. Maybe I'll coiunt on the tru-oil to add enough color (?)I wouldn't count on that. If I go the shellac route, will the tru-oil still penetrate? The shellac will adhere to the wood just fine, and if you want to put tru oil on top of shellac, that will work just fine as well. [/QUOTE
