Buss bars?
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, Apr 10, 2021.
  1. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    I've not done one of these before; the last couple of kits I built had a bar soldered to the back of the pots, but I understand that's poor practice. If I ground the various connections to the bar, what happens to the pots? Do they just connect through the chassis?
    Thanks
    sds1 likes this.
  2. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    More like poor design, the practice itself as demonstrated over and over again in various builds (commercial and otherwise) is not necessarily a recipe for trouble.
    You could, but personally I'm not a fan of things that can get loose (pots, jacks) being responsible for grounds. Also, this falls under the same "poor practice" umbrella with respect to grounds and potential ground loops. So, consider running short hookups from pots to the ground buss.
  3. corliss1
    Lansing, MI
    There's nothing technically wrong with it......but if you need to change out a pot in the future it becomes a pain.
  4. schmee
    schmee Doctor of Teleocity
    Yes, through the chassis as are all old Fenders...
    Or separate your preamp/input grounds from your PI/powersection grounds and have your bussbars separate from the pots.
  5. Lowerleftcoast
    california
    Check out Rob's Princeton Reverb site. He shows a diagram with pot connections to the ground bus wire.
  6. Nickfl
    Nickfl Friend of Leo's
    I think there might have been some confusion about what you were asking versus what was getting answered. Just to be clear if you connect your signal grounds to a bus bar you do not have to worry about doing anything to ground your potentiometer casings. They are grounded to the chassis when you attach them, and in that situation they're just acting as a shield like the chassis itself does so it does not matter where or how they're grounded.
    Paul-T, Uncle Daddy and sds1 like this.
