Building your own guitar case?
Old Deaf Roadie
Gold Supporter
Goonieville, OR
I built one waaay back in high school wood shop. It took forever, I didn’t know what I was doing, and the case died with my old Hondo II bass that I learned to play with when it didn’t survive a fall off a truck. I would approach it differently today with the advent of much better materials available, but not going to as there are better cases available in the $100-$200 range than what I can do.
Timbresmith1
Central TX
I have. It was a lap steel case, but I wouldn’t hesitate to build another.
I wouldn’t bother with a case for an acoustic tho, except as an exercise in vacuum forming or laying up veneers.
cfay
Fairhope, Alabama
I built a badass hard case for my last custom build for around $60 and got all of the hardware at a local hardware store. Since it was so easy i think I’ll start doing them for all builds since cases have gone up in price and most are a mix of cardboard’s and other cheap materials.
My wife helped and we used plywood, memory foam, yoga foam block for neck rest, leather and some hot glue and staples. Just make a plywood box, cut it down the middle and attach the hardware and foam etc. Took about an hour total and saved easily $150+ for the case quality it ended up making.
yegbert
Maryland
You can buy a much more lightweight and plenty strong case that is made of a plastic-like material formed with strengthening ridges on the outside and has a formed foam-like covered liner that is plenty protective. Your ease of getting it around will make it easier to handle, and you will likely to get it out to play often. Your back will thank you for it, too. Mine is made by SKB.
Freeman Keller
Not only do I not build my own cases I learned early on to build to fit available cases. I have made three guitars that required custom cases and they are expensive, long delivery and very heavy.
schmee
I simply relined a Gibson case once. That taught me that I dont even want to do that much again, much less build the whole thing to save $85!
ReverendRevolver
Ohio (Nerk)
You don't wanna know what's in the hotdog....
When my US tele showed up, the seller basically viewed the broken case as packaging materials.
I knew it would hold up if the hinges got reattached, as the aluminum trim parts were still intact. So I pried up the glued in Styrofoam with a fabric facing, used a screwdriver and pliers and fixed the case.
So yea, Styrofoam. And molded plastic.
I'm certain you could build a pretty solid case for under $200, but finding the right kind of dense padding foam would be tricky.
I'm staring at an unused sheet of 1/16" veneer type ply, and know I have 7ish glass cases incoming at work which will ship with multiple 30"×75" pieces of the right kind of foam that I could use. Plus I have guitars without cases.
And I'm not doing it.
I turned a backpack from Amazon into something I can use to haul my Frenzel head to gigs, and it reassured me that if a "case" doesn't reasonably exist for something, I can do it. But I'd need a reason.
When I build stuff out of wood, it has heaviness to it. When I'm playing with foam, I don't think to myself "this would protect a $1000 instrument ". So no.
I'm thinking short scale fender gig bag that holds 2 guitars. Maybe.
Telekarster
Earth
There's only 1 time that I contemplating building a case, and it was for an unusual acoustic guitar that was very odd shaped and didn't have a case, and no case would properly fit it. So.... I looked into all of it and suffice it to say, it would've cost me at least 300-400 bucks to make the case, using quality parts etc. I ended up not buying the guitar so it was moot. No, I wouldn't make my own case unless I had no other choice. Lots of work and lots of $ vs. the benefit IMO
RetiredUnit1
SoCal
I've thought about this too. Making it light enough while retaining the structural support to prevent damage to the guitar during accidents is a daunting task that could take quite a bit of experimentation to achieve.
stale facet
Rhode Island
A lot of replies!
Everyone who said there are perfectly good cases for $100, and that it's too hard to do: I agree. It is too hard to do. It isn't something I'd want to do, yet here we are.
@cfay is close to my thinking on this.
The issue is that I don't like the options. The materials being used seem like a waste of resources for something that is meant to be highly functional, and secondary to the instrument. If it's a deluxe model, it's understandable why someone would want a nicer case.
Injection-molded plastic, tolex, styrofoam, freshly harvested wood, leather—why use any of these materials at all for a case? There must be better options for new cases out there.
RickyRicardo
Calgary, Alberta
I guess it boils down to where you go with your guitar. If you want to take it on a plane then a metal one would be necessary. And no matter what you decide you probably won't get away without using some of the resources you mentioned. The reason they use plastics is because of weight.
Personally, I wouldn't do it but that's me.
If you decide to build then please post it here.
wadeeinkauf
Monterey CA
I like the idea of a paint on material.
coating is: Acry-Tech DuraTex Black 1 Gallon Roller Grade Speaker Cabinet Coating $89.00 Quart is $44.00 Quart-sized kit covers 20 to 24 sqft.
Peegoo
Beast of Bourbon
That speaker cabinet coating is the same stuff as pickup bedliner coating--which is a lot cheaper.
Slowtwitch
South Africa
There was a similar thread like this think last year, or earlier this year.
I've done it for a guitar not fitting a standard case. Wouldn't consider it for a normal fitting guitar.
It's more work than you think, and normally heavy, but robust and not too much cost saving compared to a cheap case IMG_20191119_180642.jpeg
