Building myself a guitar cab with three 8-inch speakers but...
Discussion in 'Bad Dog Cafe' started by Blazer, May 25, 2020.
  1. Blazer
    Blazer Doctor of Teleocity Ad Free Member
    The Netherlands
    Well, over the years I converted three practice amps into heads and was left with three 8-inch speakers and I had the idea of putting them all into a cab, problem is one of them is 4 Ohm and the other two are 8 Ohm.
    Is there anyway I can hook those three up together with no trouble?
  2. RomanS
    RomanS Poster Extraordinaire
    Vienna, Austria
    Two 8 ohm speakers in parallel = 4 ohms; then hook that pair up in series with the 4 ohm speaker = 8 ohms.
    saltyseadog, schmee, Torren61 and 2 others like this.
  3. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Yes.
    Wire the two 8ohm speakers in parallel for 4 ohms. Then wire the single in series with the parallel pair for 4 + 4 = 8 ohms.
    Beware that the three speakers may be different efficiency, one may be louder than the others even though they will all get equal energy.
    PhredE and radiocaster like this.
  4. stxrus
    stxrus Friend of Leo's
    St. Croix, USVI
    Beat me to it
  5. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    what speaker impedance does your amp require? 8 ohms (as described above) is almost always good. But you should check to be certain.
  6. Blazer
    The Netherlands
    Well, here's the head that I'm building around the Chassis of a Vester Maniac amp.
    It's not done yet, I have to sand the cab, the top isn't connected yet and there's more details I have to get right before assembling it.
  7. Ringo
    Ringo Poster Extraordinaire Silver Supporter
    Memphis TN
    You could wire up the speakers as noted above and try them out before you build a cabinet.
