building a super-light cab: what wood?
Discussion in 'Amp Central Station' started by Jupiter, Feb 23, 2020.
  1. LightningPhil
    LightningPhil Tele-Meister
    Nottingham, UK
    Make it out of mint. You can get waffer thin mint:
    Waffer thin materials must be lighter than big fat materials.
    Jupiter likes this.
  2. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    Almost done!
    4 panhead screws to hold the grill on. Might paint em black to hide em.
    Got the handle mounted over the center of gravity; one of my biggest regrets on my first cab was failing to do this...
    Got my Lil Texas mounted in there; I used wingnuts in the back so I can hold with my fingers when I tighten em with the screwdriver from the front.
    Not yet pictured is my phase-reversal switch; I gotta attach a little wooden bracket to hold the switch inside the box, cuz I don’t want the toggle protruding from the back.
    These are gonna be the corner protectors and feet:
    Unless I decide later I need rubber feet...
    According to my bathroom scales it currently weights 6.5kg/14.33lbs! So prolly under 15lbs when all done. :)
  3. Bristlehound
    Bristlehound Friend of Leo's
    Wales
    Nice work!
  4. Jupiter
    Osaka, Japan
    Thanks, but this thing is SUPER basic! The phase switch is a bit of a fillip, but everything else is as low-tech(nique) as it can be.
    I’m pretty pleased by how light it is, but a bit nervous about how it’s gonna sound...hope I don’t hate it!
  5. Bristlehound
    Wales
    Nothing wrong with low-tech. It is, after all, just a box with a big hole. The rest depends on how pretty you want it to look.
  6. Jupiter
    Osaka, Japan
    It’s all black now! Time to wire it up and hang all the bits on it.
    I got a bigaz 10-12A DPDT on-off-on switch, and I’m gonna wire it like so:
    except “from pickup” is “from amp” and “output” is “to speaker tabs”. If that is going to blow it up, please tell me in the next 30 minutes! :)
  7. Jupiter
    Osaka, Japan
    Well it works! Had a bad moment when I fired it up and...no sound came out...then I remembered the switch in back is on-OFF-on. Lol
    Alamo likes this.
