A guy (Jonny Reckless) over on diystompboxes.com posted his J113 preamp/amp design and a video demo of it.
schematic...
video...
Thanks, that's very cool stuff indeed.
schematic...
video...
They are intended and marketed as mainly switches, sure, but that does not mean they have characteristics that make them unsuitable for audio. I have found an old FET databook here, you can find lots of info on different FETs and their manufacturing processes. It seems actually that some FETs marketed as 'general pupose audio' have been given that label because they are not good for anything else. The J11x series has a lower noise level and higher transconductance than many 'audio' FETs.
Of course they are not as good as audiphile devices like the 2sk170, but hey, they cost only 40 cents or so. For lo-fi purposes like guitar preamps they work really well i think.
Agree about too much fizz. Seem to recall another vid where I liked his amp better. Was it this one? I don't remember. I had the Fet handbook years ago, wonder if my brother threw it out also. He threw out our version of the Audiocyclopedia, which was a shame.That Rosie amp sounded pretty good, but with a little bit of fizz on top. I bet a low pass EQ filter could be used to cut off the fizz.
Looks like fun, and sounds like you're going to have a lot of headroom... I've built a few of the little Ruby amps, with a Jfet feeding a 386 8pin amp chip, where I think they are supposed to put out about a quarter watt, from a simple 9 or 12 volt supply, it might take up to 15 I don't remember, but they sound incredibly good, and plenty loud for a table top, and even busking outdoors. I remember years and years ago someone saying something to the effect of - speaker technology being so inefficient that if they could reproduce 100% of what they were given you could power an instrument in a coliseum with one Watt!? I doubt if it was James b Lansing, Alvin Altec, Carla Klipsch or Saul Cerwin-Vega that said that, maybe it was Estes Electro-Voice?This is a simple amp, I want something small that I can plop down on top of my desk and have it take up the least amount of real estate. Originally I was going to make a pair of small cabinets with a 8" in each with a stereo tube amp for them. I built up the cabinets already but I would have to get rid of a paper tray holding work I need to get to and I am not ready to dump it. I already procrastinate getting to it and if I put it out of site, well it disappears and it is not a problem anymore. Not a good thing. So in the meantime a little amp would do me just fine.
I was going through my parts and have a pair of TDA2005 Chipamp IC's. I had them for a bunch of amp testing, SS watts as compared to tube watts and the like. Just to amuse myself. One day. For now one will be pressed into miniamp service. I have a 5" car speaker, the cabinet will be roughly 7.5" x 6.25" x 5". A laptop brick as a power supply, the chip can run bridged and will make about 12-15W depending on voltage and speaker impedance.
Seems funny something this small took all day to build. Mind you, you can only get so many clamps in play when the clamps are bigger than the box.
Most speakers are only 1-5% efficient. Horn loaded it can get up to 50% (from memory, the Audiocyclopedia was my source for some information on horns).Looks like fun, and sounds like you're going to have a lot of headroom... I've built a few of the little Ruby amps, with a Jfet feeding a 386 8pin amp chip, where I think they are supposed to put out about a quarter watt, from a simple 9 or 12 volt supply, it might take up to 15 I don't remember, but they sound incredibly good, and plenty loud for a table top, and even busking outdoors. I remember years and years ago someone saying something to the effect of - speaker technology being so inefficient that if they could reproduce 100% of what they were given you could power an instrument in a coliseum with one Watt!? I doubt if it was James b Lansing, Alvin Altec, Carla Klipsch or Saul Cerwin-Vega that said that, maybe it was Estes Electro-Voice?
Have the Spin chip also, for some reason I found it hard to get back then, no idea on now. I found a cool reverb using the PT2399 though.Fun project. I've been meaning to do an SS amp one of these days. I want something light, compact, stereo, and I wanted to cram in one of more Spin FV-1 chips (these are used in lots of digital reverbs, delays, etc) to do onboard reverb and tremolo, and possibly a rotary speaker type effect. Maybe also build a couple different preamps and switch between them -- since they're solid state they take up almost no space or power.
That’s pretty cool. What power supply are you using? I’ve looked around on eBay and you can get a 33V 1-2amp power supply for cheap. That would be enough for both discrete or chip solid state power amps pushing 8 ohms with 10 - 15W of power.I built a pedal sized 10 watt amp from TDA2003's, sounds good clean which is what I wanted it for.
View attachment 946886 View attachment 946885
Unfortunately my drill slipped for the LEDs, close enough for rock n roll ;-)
I think they’re always in and out of stock on the hobbyist sites. I’ve seen them on AliExpress though always in stock. However, transpacific shipping is a mess right now. There’s probably thousands of those chips parked off LA waiting to be unloaded.Have the Spin chip also, for some reason I found it hard to get back then, no idea on now.
It's just 9 volts from my Truetone supply, though you can use 12V. The circuit uses three TDA2003's, one as a power multiplier followed by a 15V regulator. I saw the board at TH Custom when I was getting a few others (the Merlin's Glassblower boost is my favorite!) and figured I'd make a pedal sized amp to sit on top of my 1x8" Randall cab, with a Aion Lab Series preamp up front. Fun little setup for when I'm noodling around.That’s pretty cool. What power supply are you using? I’ve looked around on eBay and you can get a 33V 1-2amp power supply for cheap. That would be enough for both discrete or chip solid state power amps pushing 8 ohms with 10 - 15W of power.
There are many possibilities for preamps. One idea I’ve had is to create a small amp version of the Vox Conquerer/Defiant (which were used by the Beatles during the Sgt Pepper era). Built in fuzz and mid-boost!![]()
But, but... ...it is a tube amp.
Oops, maybe next build.But, but... ...it is a tube amp.![]()
I wouldn't sweat too much over the specific JFET you might use. The first JFET circuit I ever made used J174 transistors, which are P channel devices recommended for switching. I used them because they were the only JFETs my surplus place had. Turns out they sound great.
I find JFETs sound great in general, very "natural", sweet sound that overdrive well. The only problem, and really not much of a problem unless you're mass producing them, is that JFETs don't always bias predictably. Trimpots, usually for the drain resistors, will be your friend.
I've been thinking that a limiter circuit before the power amp section might be a good idea. Might help keep the power section from doing the ugly distortion, if it's adjusted to clamp the signal just below the power amp's clipping threshold. Some of these limiter circuits are simple diode clippers tuned to a specific clipping level. Sometimes, they're integrated into the power amp section, such as diodes in a feedback loop set to clip at relatively high levels.
I recommend downloading the Solid State Guitar Amplifier Book by Teemu Kyttala. Find it by a google search. It's a pretty big download, but there's lots of insight to be had there.
