Speedy454
Back in the day when those power amp ICs came out, I messed with them quite a bit. I blew up a bunch of them, but back then they were pretty affordable and plentiful.
They do seem to need a good size heat sink if you plan on using more than a watt or two. But depending on the speaker, and sitting right on a desk, 1 watt could be pretty loud.
The FET preamp is the way to go. They can sound pretty good. You coud even copy some of the newer Fender solid state preamp designs and use the TL0-71 FET op amp chips to simplify things and make life easier. You may find them more stable, less noisy and more reliable than discrete FETs also.
From the previous preamp schematic, that design looks stable and clean. FET constant current sources driving fixed gain stages. On the one I currently use, I omitted the constant current sources and replaced the 1.2K resistor with a 200 ohm resistor in series with a 2K pot. By lowering the pot closer to zero and changing the drain resistor all the way down to 200 ohms, the first stage FET can get a little angry and aggressive. I had an old Univox amp with a FET input that had a Gain Boost switch that replaced the drain resistor with pretty much a short. It did boost the gain with somewhat tube like characteristics. But what did I know. That was 1977 when I was 17.
