Building A Small Amp in A Hammond Box Instead of a Chassis
Discussion in 'Shock Brother's DIY Amps' started by James Knox, Nov 6, 2020.
  1. Kevin Wolfe
    Kevin Wolfe Tele-Meister
    Lakeland FL
    A good Speyside is my personal fave!
    A tidy build and I love those eyelet/terminal thingys.
    James Knox likes this.
  2. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    Kevin Wolfe likes this.
  3. tubelectron
    tubelectron Tele-Afflicted
    France
    Well yes. It is certainly possible - I never experimented it for guitar amplification, but it works well for Hi-Fi with a Hammond 1550J aluminium enclosure - at least under mono block form :
    My Ultimate 300B :
    My Ultimate OTL6080 :
    -tbln.
  4. James Knox
    Phoenix
    Your stuff always gives me the shivers Brother! #amazing
    Kevin Wolfe and tubelectron like this.
  5. tubelectron
    France
    Thanks @James Knox ! :)
    For use in a combo, the clearance angle of the sides can be a problem since all the faces won't be perpendicular. It may be an issue for housing the box straightly in the cab...
    https://www.hammfg.com/files/parts/pdf/1550J.pdf
    -tbln
  6. awasson
    awasson Poster Extraordinaire Silver Supporter
    Vancouver
    I’m glad I tuned into this thread. So many impressive builds as examples. It’s inspiring.
    I did this on a Hammond Chassis a few years ago. PP EL84, variation on an Orange Tiny Terror with an effects loop. Point to point so the chassis was actually pretty roomy. It’s a 12 x 8 IIRC. Simple plywood box with mitred corners and maple veneer.
    07D4FBE3-3DBF-48A7-A9F7-6EFCFE625B1E.jpeg 250B8841-7EBD-4750-80AD-4E7CE2D75276.jpeg 0ADB6970-04DB-4691-80F1-5A04E42D1AEB.jpeg
  7. Kevin Wolfe
    Lakeland FL
    Yep...me too!
    tubelectron likes this.
  8. Meteorman
    Meteorman Tele-Holic
    State College PA
    this is one of Rob's Deluxe Micros in a 7"x 7" Hammond enclosure.
    It's has some "unorthodox" qualities, like the board mounted upside down to the cap, and some hook-ups to the bottom of the turrets.
    Of course the enclosure is then screwed to the base, and the board is then "components-up".
    This configuration would not be "repair-friendly" - but fortunately it works fine and sounds great as is.
    I laminated the entire inside of the base with vinyl, plus put a passive standoff on the bottom of the board, to prevent any sagging/shorting.
    This was a re-fit from an earlier config that I didn't like - you can see I did some rough machining of my own PT mounts to make things work.
    Shockingly, given the little capacity for lead dress, this thing is real quiet.
    my 2-cents - punches for the tube sockets are worth every penny.
  9. James Knox
    Phoenix
    Wow - love that! You got the Jewel Lamp Assembly in, used a normal fiber board and I really like the OT on the inside.
    Is it “headphone” only?
    awasson likes this.
  10. Meteorman
    State College PA
    nope - there's a speaker/cab jack between the headphone jack and the PT.
    you can see it behind the V2 shield/case.
  11. FenderLover
    Minnesota
  12. awasson
    Vancouver
    Like I said before, these examples are inspiring. I’ve lost track of what my next fall/winter amp project will be but this is giving me some pretty clear direction. I love the clean look of it. Just fantastic.
