Building a 14" wheel buffer.....for way way under $700
Discussion in 'The DIY Tool Shed' started by Muzikp, Jul 3, 2013.
  1. Muzikp
    Muzikp Friend of Leo's
    Sacramento
    I made do with a buffer wheel on my drill press for a long time, although my drill press head rotates 90 degrees so I could get the buffs oriented the same as a buffer would which helped.
    I found this old picture of my previous setup.
    But remember this shell pink body I painted for Rob? Polished up real nice...
    But I burned through the finish in one little tiny spot. I felt like I couldn't get the right buff speed on the drill press. Speed has a lot to do with how much heat you build up in the buff, too much heat in the buff is very very bad.
    The drill press setup did not have enough room to work though, too easy to bang the body on the drill press due to limited space. This is so much better than the drill press setup, totally worth it.
  2. charlie chitlin
    Kimberton
    Motors from washers and driers are easily scrounged.
  3. Bongocaster
    Bongocaster Friend of Leo's
    From the home of King Records
    Just can't help myself. It's for metal and not for wood but I get a kick out of the huge old motor that puts out a whopping 3/4 hp (that's .56 kW in foreign devil measurements ;) ). That's an 8" wheel to give you an idea how big this is.
    Got it as is from the basement of an old girlfriend. There was an old guy there who used it repairing vacuum cleaners. It works fine, especially for how often I use it.
