Build thread - Robrob Deluxe Micro and 5F2A
Discussion in 'Shock Brother's DIY Amps' started by Drew617, Jul 26, 2021.
  1. Drew617
    Drew617 Tele-Holic Silver Supporter
    North Shore, Mass.
    Why not start another one.
    I'm going to build two little amps in 6x4x2" Hammond chassis, a 12AU7 Deluxe Micro and a 5F2A clone. Both diode rectified, and both using WRVBPT power. That transformer is too awesome at $25 not to use frivolously. I'll resuse Hammond iron as OTs: a 1760C and their Fender reverb transformer.
    I'm going to do these point-to-point, which I haven't attempted before, although I'm still going to build power supplies on a little board since I at least have to mount a rectifier somewhere.
    I suppose these are inspired a bit by the little Milkman 5F2A clones that came out a few years back. As in, "I bet I could do that for $100." I would've liked a square chassis - might have been able to stuff everything into 4x4", but I've used a number of these Hammond 1441s now and know how to work with them, so used what sizes they offered.
    Cut a few up the other night with my Ryobi hand drill and christmas tree bit:
    Punched, deburred, and painted. I scuffed the power coat on both of these pretty badly, so decided to paint these. Have thought about doing that with others but declined so far, assuming adhesion will be an issue.
    The green is satin Rustoleum, which sticks to the powder coat much better, but is harder to spray well. My paint looks amateurish but will do fine here. The tan is Krylon which applies beautifully, but doesn't stick too well. I've already knocked some off and will have to touch it up.
    My iPhone has hyped these colors up. They're a lot closer to OD and desert tan in real light.
    Assembling and populating the chassis. The handles are $1.50 cabinet pulls.
    Insides:
  2. James Knox
    James Knox Tele-Afflicted
    Phoenix
    Nice!
    I wanna build a 5C1 SJ7 Champ in one of those box’s. I’ll be following your build and learning....
    Drew617 likes this.
  3. wallybob
    wallybob TDPRI Member
    Iowa
    Good luck - that will be10 lbs of stuff in 5 lb boxes!
    Drew617 likes this.
  4. Drew617
    North Shore, Mass.
    Thanks! Shouldn't be too bad - these boxes aren't that much smaller than a real 5F1 chassis. Don't think I'd want to lay the whole circuit out on a board and try to fit that, however.
    Transformers fitted to chassis:
    maccullt likes this.
  5. maccullt
    maccullt TDPRI Member
    Ottawa, ON, Canada
    They look awesome. I was thinking of using circular led power switches. Are yours illuminated? Do you have the part number?
    Drew617 likes this.
  6. Drew617
    North Shore, Mass.
    Yes! I’ve been using integrated IEC-fuse-rocker switch assemblies in bigger amps, plus a big LED up front that gives the impression of a jewel lamp. Still saves a ton of space and messy wire routing.
    These are more compact still. Feel a little cheesy versus a Carling toggle but they’re rated 10A and haven’t melted on me yet:
    Red Light SPST 3-Pin ON/Off Round Boat Rocker Switch AC 6A 250V 10A 125V 5 Pcs https://www.amazon.com/dp/B07CCJF2YR/?tag=tdpri-20
    The front mounting flange isn’t very wide so you have to be real careful cutting holes for these (see the bit of epoxy covering a goof on my green chassis.) Regardless what the spec says, a 3/4” knockout punch is perfect. Nibble a little notch at 270 degrees to accommodate the channel that keeps the switch from rotating.
    After building a large handful of amps for myself, starting with some faithful Fender clones, I’m happy to cast away some anachronistic nonsense normally associated with those. 6.3V pilot lamps especially included.
    maccullt and 2L man like this.
  7. Drew617
    North Shore, Mass.
    Wired a couple little power supplies:
  8. James Knox
    Phoenix
    Cool! The “little black box” is a Diode Rectifier?
    Where does one find those?
    Drew617 likes this.
  9. Drew617
    North Shore, Mass.
    Wiring the IEC inlets, fuse holders, and illuminated power switches.
    maccullt and Tele Slacker like this.
  10. Drew617
    North Shore, Mass.
    Yes sir! Tubedepot and Mouser have them, at least. As far as I know it's just four diodes in epoxy inside a little plastic box. Could just as easily do the same thing with four diodes, and I've preferred to do that where there is space and just looks/feels better to me. Here though, there's a little bit less exposed lead, risk of shorting something, etc.
  11. James Knox
    Phoenix
    Hey @Drew617 are those Hammond box’s the 4X6X2 or the 5X7X2?
    Drew617 likes this.
  12. Drew617
    North Shore, Mass.
    Hey James, these are 6-4-2. Was hoping to get these wired up today, now more likely over the weekend.
  13. Drew617
    North Shore, Mass.
    Wiring pots and sockets on the 5F2A:
    Power supply board installed:
  14. James Knox
    Phoenix
    Nice job!
    I like the Patina look of the Trannies.
    Rattle can?
    Drew617 likes this.
  15. Drew617
    North Shore, Mass.
    Woohoo... 5F2A is healthy right out of the gate. 379 B+ and dissipating about 15-16W. Successful first PTP build, or I suppose kind of a hybrid.
    TobyZ28 and James Knox like this.
  16. Drew617
    North Shore, Mass.
    Rust-oleum "hammered" black, although it's definitely a little silvery. Adhesion isn't great and it never feels like it's absolutely cured like real enamel does, but it's good stuff, hides all manner of sin. These Weber WRVBPT transformers are cheap as chips and super useful, but they're ugly.
    James Knox likes this.
  17. James Knox
    Phoenix
    Can’t wait to see the next one!
    Did you raise the value on the first Filter Cap with the Diode Rectifier since you didn’t need to worry about the 5Y3? How high did you filter on the Power Rail?
    Drew617 likes this.
  18. Drew617
    North Shore, Mass.
    Thanks - hoping to get the Deluxe Micro wired up within a few days, then finish my Nighthawk clone.
    Cap values are fairly stock, 22-10-10 here. My preferred compromise for an honest 5F1/2 combo is 33-22-10 but I have a Maggie build that’s essentially a huge 5F2 already, and am planning a Champ-ish KT66 somethingorother. Wanted to leave this one fairly true to the real thing.
    Later VCs used 40uf at the first node, so you don’t have to be guided strictly by the GE 5Y3 chart here.
  19. Drew617
    North Shore, Mass.
    Here we go, a completed PTP (ish) @robrob Deluxe Micro. Didn't have opportunity to give this a shakedown tonight, but unless I've miswired something, we know how it will perform (stupid fun!) Time to dust off my Cortez the Killer.
    Wiring the tube sockets:
    Feets and bottom panel:
    All done:
  20. James Knox
    Phoenix
    Beautiful Job!
    (I’m following in your footsteps...)
    Drew617 likes this.
