Badside
Just finally started building today after 2 weeks of planning (measure twenty time, drill once... hopefully)
I don't typically do commission builds for a bunch of reason, but this friend insisted. Not sure what I have gotten myself into.
After playing through a bunch of my builds he settled on my little SLOey practice amp for the lead, and my "Vibroverb without the verb" combo for the clean.
I figured it needed something in between, so I'm adding an extra mode to the SLO side (with its own Drive and Volume) which will bypass 2 stages (which is what the clean mode is on my SLOey practice amp). Gives a Plexi kind of clean that gets all gooey when you crank the gain.
The amp will include an FX loop and a post loop solo boost.
So... 3 footswitchable options in total (switch between the Fender and the SLO side, and between the "Rock" and the "Blues" variants on the SLO side)
5 relays needed.
The whole thing needs to fit on his cab which is 20x10 on the top (slanted vertical 2x12), so starting with a 18.5x8 chassis.
Printed my plan on big sheets... unfortunately I apparently move the board component on the full layout plan before exporting, but it's alright I know where things go.
Cut the drilling plan to size
And went to town
Some interesting things:
- The Relay supply uses the 5VAC rectifier tap off the 290DX power transformer since I don't use a tube rectifier. Using a Delon voltage doubler configuration I can then regulate down to 5VDC and it's super stable. Will be my 4th time using this config. Also using this clean 5VDC to power LED indicator.
- The channel LED indicator will go Green for Fender Clean, Orange for the "blues" mode and Red for the full lead mode. Basically, the relay for the channels lights up the Green side of a dual color LED when in clean, and the Red side when in SLO mode. Then the relay for the sub-mode lights up the Green side only if the Blues mode is activated. So if the amp is set to clean, it doesn't matter if the SLO side is in lead or blues mode, the light will be green. But once the SLO channel is engaged, going to blues will make it go orange by way of lighting both the red and the green! Or at least that's the plan.
5 relays needed.
And went to town
