Build Progress! Wiring (not) fun :-/
Discussion in 'Tele-Technical' started by Likeabrave, Sep 19, 2020.
  1. Likeabrave
    Likeabrave TDPRI Member
    Las Vegas, Nevada
    Shielded everything with copper tape and continuity checked out. Pickups are mounted and threaded through to the control cavity. So far so good!
    The electronics were pulled from a Vintera Modified 50's telecaster, which is supposes to have the same wiring scheme as a Classic Play Baja. Fender's diagram for the CPB show a black, yellow and green wire from the neck pickup. I have a black, yellow, and WHITE wire.
    I would have assumed the white is the new green except the clipped end of a white wire is on the s1 switch lug where the diagram suggests the yellow wire should connect, the and the clipped end of the yellow wire is running to ground on the tone pot!
    I'm going to go with my gut and solder the pickup based on the wire color remnants unless anyone has a reason to talk me out of it:)
  2. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Two of the wires should be the ends of the coil winding, therefore should have continuity of course with your coil resistance. One should be the cover ground, no continuity with the other two.
    To get the polarity you want, connect your VOM to the coil wires of one pickup. Set the VOM for its lowest D.C. Voltage scale. Hold a screwdriver next to the pole pieces, then move it away while watching the meter. You will see a brief positive or negative reading. Repeat with the other pickup.
    Both positive or both negative = in phase.
    garrett and Likeabrave like this.
  3. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    There are 2 versions of the Twisted Tele neck pickup. The Baja and the 2012 Am Std/Twisted Tele retail sets.
    It's a good bet that the Vintera Mod wire colors are now the same as the retail sets. Unfortunately Fender haven't released the Vintera service diagrams.
    The Baja version is Green - cover ground, yellow - coil hot, black - coil ground.
    Am Std, Retail Set, (Vintera Mod?) Yellow - cover ground, white - coil hot, black - coil ground
    Baja Twisted Tele Neck
    Normal Twisted Tele Neck (Fender recently have started to solder the cover grounds like this).
    Likeabrave likes this.
  4. Peegoo
    Peegoo Friend of Leo's
    Wyoming panhandle
    In addition to the good advice above, use your meter to test continuity across the metal pickup cover and the ends of the three leads to establish which one is the shield ground. Do this with the leads disconnected from the circuit.
    Likeabrave and Ricky D. like this.
  5. Likeabrave
    Las Vegas, Nevada
    Thank you! This is exactly what I needed to know.
  6. Likeabrave
    Las Vegas, Nevada
    Thanks. Confirmed yellow is ground!
    Peegoo likes this.
