Bugera v22 soundcheck (video)
  • Thread starter Junglehood
Junglehood
greece
Hello i am a new member i just recorded a video that want to share with people that need helps about this amp!after some months of researching i bought the Bugera v22 and i am very satisfied! I did a video that you can hear how the Bugera v22 sounds from Line/Send Recording and no Mic!its something i was searching and i coundt find so here it is for people that are intresting.
!there no guitar skills just played some tones for record!
-Hawk-
IL, USA
Can you explain what you mean by line/send recording? I'm a dummy, but also have the amp and am very interested in using it to record.
buddhuu
Herts, UK
Presumably Junglehood used the FX loop send as a line/DI out for recording purposes?
Works fine on some amps, less well on others. The Laney Cub 12R, for example, has the FX send jack labelled as both send and line out.
Sounds like he used the Bugera's loop output in the same way.
Junglehood
greece
Thats what i did! For example also In this Way u can get the Reverb Effect from the amp if you like it and mix it in your Console as Aux.
