Budget vacuum press?
Discussion in 'The DIY Tool Shed' started by goodchicken, Dec 2, 2018.
  1. goodchicken
    goodchicken TDPRI Member
    US
    I'm going to do an arm carve on a Tele (and maybe a carve top on one in the future), and I have some purdy veneer to glue on. I tried testing with clamps, but it was a bit problematic.
    I had read somewhere in the past (probably here, but I can't seem to find the thread) about a fairly cheap DIY vacuum press setup. Seemed like it used some stuff from Harbor Freight.
    Any thoughts on this or vacuum presses in general is much appreciated :)
  2. dkmw
    dkmw Poster Extraordinaire
    Florida USA
    Vacuum is the way to go for veneers - but there's a bunch of things you need to buy to get set up. The bag material, pressure gauge, mastic, tape, fittings, veneer softener, breather material; and then there's the pump. You could use a household vacuum for a small piece like a guitar body, but it would barely work and almost surely kill the vacuum cleaner
    A big aquarium pump might be enough. A fridge pump would work, but you have to find one. Pressure needs to be held for duration of initial set/cure of adhesive. you can either have a regulator control pump cycles or sit there yourself and babysit
    Definitely test before you do your real work. There is a learning curve.
  3. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    I have bagged epoxy with a shop vac, taped plastic film and polyester fabric for a release film. That's easy, but nothing like doing good veneer. How do you keep it neat?
  4. sergiomajluf
    sergiomajluf Tele-Meister
    Santiago, Chile
    Would a storage vacuum bag work for this?
  5. DrBGood
    DrBGood Tele-Holic
    Sutton QC, CANADA
    I have an old vacuum pump from a priinting company. I build windsurfers with epoxy/Divinicell sandwich with it, so plenty of pressure from it. A fridge motor would be a cheap source though.
    There is a learning curve, like dkmw said.
  6. Boomhauer
    Boomhauer Friend of Leo's
    Michigan
    goodchicken likes this.
  7. Mike9
    Mike9 TDPRI Member
    Chatham, NY
    That's a slick setup @Boomhauer
    Vacuum is the way to go IF you want to invest in the setup. I used to lay up miles of veneer back in the day. You have to make a platen to evacuate the air. I made mine from 3/4" melamine and used an old refrigerator compressor for a pump and bought a vinyl veneer bag and a pressure switch. I let the freon out then stuck the exhaust port in a jar to catch the oil. I used that setup for years with no problems.
    You could also "hammer" veneer using hot hide glue.
  8. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    Jim_in_PA likes this.
  9. ecoast
    ecoast Tele-Holic
    NWNJ
    just rent the vacuum pump (used to suck down A/C) from advance auto
    give deposit (full price of pump)
    use
    return
    no problem; this is how their tool rental program works
  10. printer2
    Vacuum cleaner, food wrap plastic film, masking tape.
  11. spartan warrior
    spartan warrior Tele-Meister
    Wokingham, Berkshire. UK
    I used a vacuum storage bag as suggested above by sergiomajluf when gluing the 6mm thick front and back onto the core for a body and it worked a treat.
    I used a domestic vacuum to pull most of the air out, then used a wine-saver type hand pump to get the last bit out.
    I glued it using Titebond first thing in the morning, and kept checking every now and then that the vacuum was holding, giving a few more pulls on the hand pump if needed.
    By the end of the day the Titebond had cured enough to hold firm, but I left it in the bag over night, just for good measure.
    Vacuum is definitely the way to go when doing something like this. On a body sized bit of wood measuring say 17 inches x 14 inches, the surface area is 238 square inches.
    Even if you can only pull 25% of a total vacuum that means each square inch is seeing 14.7 x 0.25 pounds of force (14.7 being atmospheric pressure in psi) = 3.6 lbf.
    That means the whole surface of the body is subjected to nearly 860 pounds force, over 1/3rd of a ton. Best of all, it is evenly spread over the whole surface.
    sergiomajluf and Mat UK like this.
  12. spartan warrior
    By the way, the clamps and aluminium T section spreaders were there for insurance before I established that the vacuum would reliably hold.
  13. SacDAve
    Rocklin Ca.
    Some one gave me this I’ve had it a couple years. I think its time to put it to use Maybe a Vacuum table. Can’t find to much on this model but seems to still be in use deferent model number.
    From link Blood analysis, respirators/nebulizers, vacuum pad hold-down, dental/surgical, automobile cruise controls, graphic arts equipment, air and gas analysis, breast pumps, sterilizers, air brushes, agricultural foam markers, oil atomizers and lab equipment.
    https://www.rg-group.com/product/doa-v722-aa/doa-series
  14. trev333
    Coolum Beach,Australia
