Budda Superdrive 45 KT66 to 6L6 swap?
Discussion in 'Shock Brother's DIY Amps' started by JCSouthpawtele, Sep 9, 2010.
  1. JCSouthpawtele
    JCSouthpawtele Friend of Leo's
    Middlebury,Indiana
    I have a superdrive 45 in my shop tonight that needs to be running by a saturday gig. It popped a fuse so I believe the power tubes are toast. This is a cathode biased amp so is it possible to replace the KT66's with 6L6's. Plug and play? I have had this amp on my bench for other little things like the Clean volume balance mod that I have done on several Budda's to date . This one keeps coming back with other issues down the line. like bad solder joints on the green(heater line) from the first tube to the second so it burned up the tube. and now kicks the fuse.
  2. JCSouthpawtele
    Middlebury,Indiana
    swapped and played throught it for about 30min then on standby for a15 min break then back on. no issues.
