Broken neck curiosity: how broken is too broken?
Discussion in 'Tele Home Depot' started by stale facet, Sep 5, 2020.
Tags:
  1. stale facet
    stale facet TDPRI Member Silver Supporter
    Massachusetts
    Got this tele neck as part of a recent purchase. The tuners will go to the next project, but after looking at this I wondered: how broken is too broken to fix? Some people do amazing repair work—is this something anyone would attempt to save? Just curious, thanks!
  2. pdmartin
    pdmartin Tele-Meister
    Chillicothe- the armpit of Ohio
    It’s a clean break. I’d try it.
    Danb541, mojek, crazydave911 and 3 others like this.
  3. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    I think just about anything CAN be fixed. It depends on your skill level or depth of pocketbook. The question is, is it worth it?
  4. Freeman Keller
    I would repair it but there is a very good chance that it will not be straight after the repair and would require pulling the frets and planing the board. It looks like its at the 12th fret, dealing with the truss rod might be a problem too. Finish is always tricky, if this is lacquer it would be easier.
    Telenator and crazydave911 like this.
  5. john_cribbin
    john_cribbin Tele-Afflicted
    London
    Would the truss rod have a 30 degree bend in it my any chance?
    Wally, crazydave911 and DjimiWrey like this.
  6. Recce
    Recce Friend of Leo's Silver Supporter
    Northern Alabama
    That looks remarkably like firewood.
    SheldonP, Wally, ale.istotle and 7 others like this.
  7. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    That's not too broken, if you REEEEEEALLY want to fix it. The truss rod needs to be replaced, which is major surgery.
    Unless it's a really cool neck, why bother?
  8. telemnemonics
    Can fix vs worth fixing
  9. Peegoo
    Peegoo Poster Extraordinaire
    Wyoming panhandle
    Totally fixable.
  10. DrBGood
    DrBGood Tele-Holic
    Sutton QC, CANADA
    If there's not wood missing, go for it. Pull out the truss rod, straighten it and voila ! If it doesn't work ... it doesn't work. An once of wood glue will have been lost in the process.
    crazydave911 likes this.
  11. ReverendRevolver
    ReverendRevolver Tele-Afflicted
    Ohio (Nerk)
    No harm in trying. Even failure is experience gained.
  12. green_henry
    green_henry Tele-Meister Silver Supporter
    Pleasant Hill, CA
    Looks like it's also missing 2 frets. If you already have glue, clamps, and frets, it might be a fun project, but if you need to lay out any money, I think I'd save it towards a new neck.
  13. Dacious
    Dacious Poster Extraordinaire
    Godzone
    +1. I'd give it a shot with trussrod back off and possibly removed but it might need planing.
    Greg Allmans Goldtop had 3 breaks apparently.
  14. stormin1155
    stormin1155 Tele-Holic
    Iowa
    I've fixed a lot worse. That is a clean break with lots of gluing surface. I've fixed breaks that were shattered in many pieces and ones where the headstock broke off at basically a 90 degree angle. The question isn't IF it's fixable, it's whether it's worth fixing.
    Wally, crazydave911 and Jakedog like this.
  15. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Looks like the infamous, "I leaned the guitar against the truck when loading out of the gig and forgot it was there until I ran it over" problem.
    It would be an easier fix to remove the skunk stripe (looks like no fretboard to remove) so you can get the truss rod out, remove all the crooked cross-bent fibers that would stop a clean clamping up, then glue/clamp. New truss rod. Replace the couple of frets with what's in there or all of them with a pack of stainless steel ones. If you replace all of the frets you could ensure a good level board. If it's a MIM/MIA Fender neck you'd have a good project. If Squier or Glarry or something then you might want to use it just for practice.
    Then find a relic body to attach to the neck and build another guitar.
  16. urbandefault
    urbandefault Tele-Holic
    OKCUSA
    It's maple. Glue it up and play the dang thing. :cool:
  17. Peegoo
    Wyoming panhandle
    No need to remove the truss rod...it's a tensioned member and does not rotate.
    Bend the rod straight, line up all the stray wood fibers, and glue and clamp that puppy together.
  18. bcorig
    bcorig Friend of Leo's Silver Supporter
    In the 909
    Better it’s your guitar than you.
    Lake Placid Blue likes this.
  19. bcorig
    In the 909
    I’m in awe of guys like you
    39martind18 likes this.
  20. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    If ya don't try, ya never know if ya can ... It's like the atheist that was caught praying.... when asked why?, he said, Hey, what do I have to loose?
    Go for it...
    r
