Jon Snell
The EL36 or 6P31S was designed as a line output valve for monochrome television receivers, back in 1940, with a maximum 7.5kv peak anode voltage so no issues there. (There were two types of EL36 in production; an Audio version with no top cap and the type with a top cap. Like the 807 which is a 6L6 with a top cap, allowing for a much higher anode voltage with no fear of arking on the valve base).
I would suggest the hum ... is it 50 or 100 HZ I wonder ... .
50 HZ is mains hum, maybe the phase splitter valve has an unbalanced heater/cathode issue or the 100R heater balance pot requires some adjustment or is faulty.
100 HZ points to smoothing issues. Check the ripple on the smoothing capacitors and compare it with the hum ripple.
