Broken headstock..can it be fixed (and is it worth it)?
Discussion in 'Tele Home Depot' started by jman72, Aug 1, 2020.
  1. jman72
    jman72 Tele-Afflicted
    Central Florida
    Hi guys,
    My buddy knocked over my OTHER buddy's Epiphone Dot and snapped the headstock off. I told him I would take a look at it and see if I could possibly do something with it. Once I looked more closely, it is a pretty nasty break, but I think it COULD be fixed. What do you all think- what would be the best way to fix this break? If I don't try, it goes in the garbage. If I screw it up, it also goes in the garbage, so no stress on a fail. I'm looking at it as a chance to learn something.
    IMG_20200801_193809718.jpg IMG_20200801_193845028.jpg IMG_20200801_193857358.jpg IMG_20200801_193906280.jpg IMG_20200801_193920604.jpg
  2. guitarbuilder
    You can scarf a peghead onto that. I would make an angle from the fretboard/ nut edge back on the underside. Then create a new peghead and glue it on and shape to match the neck carve.
    The other option is to glue the peghead back on and then rout for splines. On an Epiphone, I'd just make a new peghead as there isn't much value in the guitar.
    What I've done before is to make a sanding block with a center section open, so that once I saw a rough angle in there and avoid the truss rod, I can sand it level for the mating part.
    Is it worth it....that's up to you and your friend. This is a Gibson Les Paul I did that too. It's a good repair to learn.
  3. rangercaster
    Knoxville TN for now
    Just buy a new one ...
  4. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    It's worth a stab. It's an inexpensive and common guitar, so try the ghetto-ass easy way first, and step up in complexity as needed. The hardest part is engineering the custom clamp and cauls you'll need. Remove truss rod nut, wrap rod threads in waxed paper. Epoxy the headstock back on. See what happens. It could very well hold, or it might not, in which case you need to evaluate how much your time is worth for the more extensive approach that would need to follow. I have repaired worse without reinforcing rods, and those guitars are still going along just fine, 15 or 20 years later. You can add rods if you want, though. It isn't that hard. Personally, I would fix it if it was my own guitar, but I wouldn't pay someone else to fix it.
    treadwm, jman72 and tubegeek like this.
  5. Peegoo
    Peegoo Friend of Leo's
    Planet Peegoo
    "The other option is to glue the peghead back on and then rout for splines."
    That's how I would do it. Stronger than the original neck too.
    Fixes like this might de-value the guitar:
    Jakedog, oldfish, hepular and 7 others like this.
  6. guitarbuilder
    Splines replace the severed wood between the two parts. That break is really short and there isn't much of anything for the wood fibers to glue themself too. Here's an ugly but solid repair for a similar circumstance on a les paul. You'd be wasting your time gluing without adding splines.
    Heimdall, Wally, treadwm and 5 others like this.
  7. Fretting out
    Fretting out Friend of Leo's
    Land of Mary
    This is how my woodworking father repaired my epi dot
    It’s definitely a stable fix
    Except he didn’t quite understand the truss rod and buried it in the repair
    Jakedog, Heimdall, jman72 and 3 others like this.
  8. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    Yeah you definitely need more than 4 screws. Amateur.
  9. guitarbuilder
    Someone here had a video showing how some guy drilling holes for dowels in a similar break. I wouldn't but you might...LOL.
    Auherre756, Jipes, mefgames and 2 others like this.
  10. Peegoo
    Planet Peegoo
    Guilty! And I should've used sheetrock screws. They hold more better.
    And on this one, I probably should've pre-drilled the screw holes to keep the wood from splitting.
  11. tubegeek
    Brooklyn, NY
    Your last two posts remind me of jailhouse tattoos for some reason. Maybe because they bring a tear to my eye?
    BlueCajun, jman72 and drf64 like this.
  12. Peegoo
    Planet Peegoo
    And they usually get infected.
    Like this neck heel repair on a DC Junior:
    Heimdall, The Angle, jman72 and 10 others like this.
  13. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    And counter-sunk those flatheads to keep your thumb from splitting...
    koolaide and jman72 like this.
  14. 2HBStrat
    2HBStrat Tele-Holic
    Four Rivers Area of Middle America
    Unless it's a vintage American made Epiphone it's probably not worth paying someone to repair it. Just my opinion...
    yamatele and jman72 like this.
  15. Freeman Keller
    I have fixed a fair number of broken heads and that one will be difficult. A green stick fracture is relatively easy, one along the short grain is also not too bad. At this point in my repair career I probably would not take that on.
    However, if you do build a good caul to hold clamping pressure into the neck stick as well as aligning the pieces. I would plan to add both splines on either side of the truss rod and a back strap that covers the joint and runs into the neck stick. If the neck was removeable it would be easier to replace is, a dot is a set neck so that's not easy either.
    Normally epoxy has no place as a lutherie glue but a case can be made for it here - use slow set high strength stuff not the five minute kind. Dan Earlewine gives a piece of advice for this kind of repair - clean out any little twigs of splintered wood but don't try to test fit it until you are ready to go - basically you get one chance.
    Here us a different one following the short grain sot the glue up was simpler - for safety I added a carbon fiber spline between the two truss rods and then a back strap to add shear strength to the back.
    I made a wooden jig based on this one for doing head repairs, this one is just plain cool. The important feature is the two clamps at the end of the head which drives the break together - just trying to clamp it from the sides it will want to skate apart.
    drmordo, Wally, ale.istotle and 7 others like this.
  16. rangercaster
    Crazy glue and duct tape will fix anything ...
    jman72, hemingway and beagle like this.
  17. radiocaster
    europe
    I'd try to remove the neck from the body. Actually I wouldn't, I have no idea what I'm doing and this is a job for a professional.
    jman72 and joe_cpwe like this.
  18. Tele22
    Tele22 Tele-Meister
    Europe
    Welcome to the broken headstock club ... it was a $150 repair for my Les Paul, but it looks and plays like new.
    jman72 likes this.
  19. tigger
    tigger Tele-Meister
    Confoederatio Helvetica
    I believe a vintage correct way is to make a gallon of epoxy and plaster it over both sides before putting the two bits close to each other and drilling a few holes across for wooden dowels.
    Note that if you decide to go this way this is a proper but expensive repair. Knocked about 6k off the value of my SG.
    jman72 likes this.
  20. Ronkirn
    Jacksonville, FL
    tiz but a wee scratch.. With a moment or two in a shop and in the hands of a loving craftsman, good as new... Oh don't for get to bring ca$h.
    r
    24 track, Mr_Q, koolaide and 2 others like this.
