Broadcaster/Nocaster (50-51) neck specs/fret size?
Discussion in 'Vintage Tele Discussion Forum (pre-1974)' started by Heavy Formvar, May 6, 2021.
  1. Heavy Formvar
    Heavy Formvar TDPRI Member
    under the friggin bakelite pickguard!
    Looking into buying a Musikraft Blackguard Neck for a Broadcaster/Nocaster build...I know the neck profile was soft V-ish ("Tadeo Taper") but what size were the frets? I did a few google searches but couldn’t find anything about that.
    David
    horseman308 likes this.
  2. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    Tadeo Taper is not the neck profile per se but the transition from the back of the head to the neck profile. Most of the early necks were U or boatnecks. The blackguard area ended in 1954.
    The V neck started in 1956.
    Read here:
    http://www.guitarhq.com/fender2.html
  3. ThermionicScott
    CID
    6230 would be the closest to vintage fret size. I believe the real original wire would have been a bit skinnier than that.
  4. Adam Wolfaardt
    Adam Wolfaardt Tele-Meister
    France
    Hard V necks started in 56. Lots of V necks before then but they were a softer V. I tried a nocaster recently that had a harder V than my 55 which has a soft V. Guitar HQ is great but there are mistakes
  5. hamerfan
    Germany, Bavaria
    Thanks for the heads-up, but the only original Blackguard I have played was more of a baseball bat than a guitar.
