Brief Hum Coming Off Standby
Discussion in 'Amp Tech Center' started by JayDee, May 22, 2020.
  1. JayDee
    JayDee Tele-Meister
    Missouri
    Hello all. I recently noticed my Deluxe Reverb Reissue humming for about 20 seconds or so after I switch it off of standby. I've had this amp since around 2004 and never noticed it. It's a new sound. It seems fine after the hum goes away. Have you had this issue or know what causes it? Thanks.
  2. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Check your filter caps is my guess.
  3. Jon Snell
    Jon Snell Tele-Meister
    Jurassic Coast. UK.
    Whilst the output valves are balancing a 120HZ hum can be heard to fade out. Depending on the chassis, either reset the bias balance or replace the output valves for a matched pair and set the bias current to 42mA or your preferred heat.
  4. JayDee
    JayDee Tele-Meister
    Missouri
    Thanks for the tips. I appreciate the help.
