Bridge saddle + plat become hot
Discussion in 'Tele-Technical' started by Yazam, Apr 19, 2020.
  1. Yazam
    Yazam TDPRI Member
    Malaysia
    Hi
    I need some advice
    1. My 3013 52 reissue saddle N plat become hot when plug in, quite noisy sometimes. But the tone fuuhhh just luv it.
    2. Can we change bridge saddle only for my CS 2015 journeyman tele. I like the plat style but i prefer vintage saddke tupe.
  2. fasteddie42
    fasteddie42 Tele-Afflicted
    Tip of the Mitt
    Danb541 and Fretting out like this.
  3. dan1952
    dan1952 Friend of Leo's
    Anderson, IN
    There is no voltage going through there. Just your imagination
    Fretting out likes this.
  4. viking
    viking Friend of Leo's
    Denmark
    You mean no voltage.
    Its all in your mind , threadstarter !
  5. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    what kinda hat are you wearing?
    o_O
    edit - note source of first post.
    English may be a second, third or fourth language - it may be that WE are not reading well enough. Let's not tease (like I did at the start)
    Peace - Deeve
  6. viking
    Denmark
    Yes , please explain , maybe use some other words ?
  7. jfgesquire
    jfgesquire Friend of Leo's
    Lake View
    I think by "hot" he means bright - trebly - noisy - sensitive maybe like it's microphonic?
    Are those pickups wax potted?
    My old Duncan Tele stack bridge pickup isn't potted and it's very "hot" i.e. - microphonic. If I tap on the bridge plate itself it can be easily heard through the amp.
    Sent from my LG-H932 using Tapatalk
  8. Wrighty
    Wrighty Friend of Leo's
    Essex UK
    Your English is better than my Malayan, but I’m afraid I don’t understand your question. If you mean ‘hot’ as in temperature, I don’t think it can. If you mean ‘hot’ as in ‘output’ then I am sure a lower output pickup could be suggested by those with more knowledge than I.
  9. Yazam
    Yazam TDPRI Member
    Malaysia
    Hot in terms of temperature
  10. Yazam
    Yazam TDPRI Member
    Malaysia
    Hot in temperature.
    And maybe microphonic.
  11. Yazam
    Yazam TDPRI Member
    Malaysia
    Haha i have no idea
    Bought the guitar new in 2013. 52 reissue.
    If not wax... what should i do?
  12. Yazam
    Yazam TDPRI Member
    Malaysia
    thankyouguitar likes this.
  13. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Temperature? How hot? Hot like a cup of tea? Definitely not normal.
    Yazam likes this.
  14. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    You can certainly change the saddles, but I have never heard of such a thing and can't imagine what could make it happen, or why changing the saddles would fix it...
  15. radiocaster
    europe
    Yes, you can change the saddles if the same type (3 saddle bridge, not 6).
    But I think your problem is the ground connection to the bridge.
    Is this the problem?
    The video doesn't go into it, but there is a wire from the plate to the controls. It's not important what type of saddles, but the wire should be connected and touch under the plate.
    Yazam likes this.
  16. Yazam
    Yazam TDPRI Member
    Malaysia
    Yeah thanks man
    i should try to check it out
  17. Yazam
    Yazam TDPRI Member
    Malaysia
    Actually its 2 different guitar.
    1st guitar: Hot temperature problem
    2nd guitar: i want to change the saddle
  18. Alamo
    Alamo Doctor of Teleocity
    Berlin
    That's so hard to believe, I would try to verify it by using a point and scan Thermometer.
    someone around you will surely have one (due to the crisis going on)
  19. AJBaker
    Switzerland
    I agree. There must be a misunderstanging somewhere.
    How hot is it getting? 20C°? 40C°? More?
    Under normal circumstances, there is just no way for it to physically get hot, unless it's sitting in the sun or you're holding it to a flame.
    Do you mean that the pickup has too much output?
