Well I would understand to redrill the 3 or 4 holes to fix the bridge but I don't want to do something more difficult than that...Aria Pro did everything different. Probably nothing will fit. I had an Aria Strat, the saddles and bridge were narower than other Strats. Nothing Fender made fitted. Well the tuners but that's about it.
I ran into this on an Asian Tele before. If the string thru holes line up then just drill out and plug the original bridge mount holes (walnut or maple dowels work great for this) then drill new holes. Other option is to find an "import pattern" bridge. I believe that some Squier bridges are this pattern, but none of the Fender US (or MIM) pattern stuff will fit. Just dowel and drill and go with the bridge you want. If you don't have a drill press this shouldn't be an expensive fix for an independent repair tech to do.
I can only guess that Fender is too protective of their technical knowledge to do that. I have submitted a web page based inquiry on the matter with Fender. I’ll let you know if I hear anything back.No, never tried vintage style bridge.
I tried to mail Fender to have the specs of this bridge. That s crazy not to find any drawing on internet!
Fender responded to my request, affirming my theory that the STB holes are the same on the Pro II as they were on the American Standard, and provided detailed technical drawings of the bodies and bridges of both models. I couldn’t easily get those drawing into this post here, but if interested in the details let me know.I can only guess that Fender is too protective of their technical knowledge to do that. I have submitted a web page based inquiry on the matter with Fender. I’ll let you know if I hear anything back.![]()
