Bridge PUP and Bridge ground
Discussion in 'Tele-Technical' started by bgood, May 14, 2011.
  1. bgood
    bgood Tele-Meister
    Emerson, NJ
    Hi need some help. Replacing the PUPs in my ASAT and the new bridge PUP does not have a plate on it - Dimarzio Area T - plastic only.
    The guitar has no ground wire from the bridge to the pots.
    I'm assuming the bridge plate/screw/bridge connnection served as my bridge ground in the old setup.
    Do I need to ground the bridge with a seperate wire? If so, whats the best approach. Is it absolutely necessary?
    Thanks
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    yep
    Yes you need to ground the bridge/strings.
    One way is to have a wire with a eye terminal on it and put in between the plate and spring or tubing of the pickup when you mount it.
    Another is to pull the bridge up and slip a bare wire end under it.
    The latest is the greatest:
  3. bgood
    bgood Tele-Meister
    Emerson, NJ
    Thank you!!
  4. sjtalon
    ubetcha
    and I have to apologize as I can't give credit to who did the handywork in the pictures so I take no credit for the job.
    The lower pic is from here:
    http://www.tdpri.com/resources/diy-tele/
    and the upper is from someone who is on here a lot..........dang..... maybe mellecaster or Ron Kirn, or one of the other greats ??? won't come to me right now.
