Bridge pulling up with 12's
Discussion in 'Stratocaster Discussion Forum' started by Neill Levine, Jun 19, 2012.
  1. Neill Levine
    Neill Levine Tele-Meister
    Sydney, Australia
    I'm thinking of putting 12's on my strat. I am also over using the tremolo bar, but I don't want to do anything drastic about it (I'll probably use it again later)
    Should I just tighten the three tremolo strings in the back, so the bridge doesn't pull up with the strings? It was set up to float a little while ago, with 11's on it.
    NL
  2. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Yes, just screw them in. You may have to slightly raise the saddles, though, to get the action back where it was.
  3. Doorlord
    Doorlord Tele-Meister
    San Dimas
    I'd go with all 5 springs with 12s.
  4. Jakedog
    The North Coast
    ^ What Doorlord said.
  5. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Yeah, I think 3 springs might not be enough.
  6. Neill Levine
    Sydney, Australia
    Ah got caught up, wedding gig to prepare and all that.
    Thanks for the advice on that everybody, I only have 3 springs on my MIM strat, so I will try to get some on ebay and give it a try.
    NL
  7. Ron Garson
    Ron Garson Friend of Leo's Silver Supporter
    If the springs are on in parallel to each other, you could fit them in more of a V shape to give a little more pull, and then screw in the screws holding the "claw." Since it was alredy set up for 11s, it might not need to go much further!
  8. Neill Levine
    Sydney, Australia
    Thanks for that Ron - I will give that a try before I pick up more springs (and observe the height of the saddles and the action)
    NL
  9. gtrguru
    gtrguru Friend of Leo's
    Detroit Metro
    I use all 5 springs with 10 gauge strings and a floating trem setup most of the time. If I'm not using the trem for awhile then I will screw the claw in to pull the springs tight. Usually minimal saddle height adjustments are required. Try it. Screws were meant to be turned.
