Bridge pickup sounds same as middle switch position
Discussion in 'Tele-Technical' started by Valhalla, Sep 23, 2020.
  1. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    Sorry, this doesn't really add much to the discussion but the soldering on that switch does not inspire confidence in the tech's work.
    Boreas likes this.
  2. Boreas
    Boreas Tele-Afflicted Silver Supporter
    Adirondack Coast, NY
    Agree - I think it may be damaged (overheated?) or a short from a sloppy or cold joint.
  3. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    You could do a quick ear check by tapping with a screwdriver on each pickup while in the
    N+B switch setting. Other than pickup heights and output possible could be a weak jumper
    wire contact on the switch.
  4. DougM
    DougM Friend of Leo's
    Honolulu, HI
    A cold solder joint would cause an open, not a short. When tapping on both pickups with something metal, you should only hear the neck pickup with the switch in the neck position, and only the bridge pickup with the switch in the bridge position. You should only hear both when the switch is in the middle position.
    Make sure to tap on both pickups with the switch in all 3 positions.
