Bridge pickup "leaking".
Discussion in 'Tele-Technical' started by Nope, Sep 29, 2020.
  1. Nope
    Nope TDPRI Member
    Toronto
    I've just noticed that my 2006 American Tele FSR "leaks" when on the bridge pickup. Here's what I'm talking about:
    On the neck pickup, with the volume rolled all the way down, there is no signal.
    However, on the bridge pickup, with the volume all the way down, there is still substantial signal to the amp.
    I've tried the same cable / amp with other guitars; no signal leak, which I think points to the wiring harness on the Tele.
    Before I open this up, I'm wondering if anyone has encountered this before and can suggest a likely culprit. This is definitely a new issue.
  2. AAT65
    AAT65 Friend of Leo's
    West Lothian, Scotland
    Never heard of that before... a volume control turned all the way down basically shorts the guitar output to ground.
    So my suggestion would be to check all the ground connections. If you’re relying on the control plate to ground the pots perhaps there’s a little corrosion which means that the ground connection isn’t too good on the volume pot.
    You could start by measuring the resistance between the tip and ring of the guitar lead (plugged into the guitar, volume right down, try all 3 selector positions). A few k-ohms could make a difference.
  3. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Photo of the guts?
    Maybe take a bunch of resistance readings as well, especially on the volume pot.
    koolaide likes this.
  4. koolaide
    koolaide Tele-Holic
    south carolina
    My guess is the pot is leaking, not the pickup. As AJBaker noted, some resistance readings would tell the tale. Also maybe a wiring issue.
  5. Peegoo
    Peegoo Friend of Leo's
    Wyoming panhandle
    Probably something going on with the switch, because if it were the volume pot it would exhibit the same symptome on the neck pickup.
    What's the guitar doing when both pickups are selected?
  6. archetype
    archetype Fiend of Leo's
    Williamsville NY
    If the OP's Tele is a master volume and master tone, both pickups would go through the same volume pot. That setup wouldn't "leak" on one pickup and not the other unless it's wired rong.
    @Nope does it have 4 pots or 2 pots? Please post a picture of the backside of the control plate or pickguard, whichever the pots are mounted in.
  7. Nope
    Nope TDPRI Member
    Toronto
    Measurements off a guitar lead:
    Volume Down
    Neck: 5.61k
    Both: 4.07k
    Bridge: 5.4k
    Volume Up
    Neck: 13.16k
    Both: 4.62k
    Bridge: 6.86k
  8. Nope
    Nope TDPRI Member
    Toronto
  9. Nope
    Nope TDPRI Member
    Toronto
    @Peegoo Turns out that it's leaking in the middle position too.
  10. 63 vibroverb
    63 vibroverb Tele-Afflicted
    Lititz, PA
    I would double check the hot and ground connections from the bridge pickup, reflow the solder if needed. Then take it from there.
  11. Nope
    Nope TDPRI Member
    Toronto
    Also bears mentioning that the controls on this guitar have been untouched since 2006.
  12. Peegoo
    Wyoming panhandle
    If you did any soldering on the switch at any point, look closely at the switch's solder tab for the bridge pickup's hot lead, and follow it down to the wiper where it contacts the moving wafer (the part that rotates when you move the lever).
    Look for solder drips or a bend wiper.
    Sometimes solder will wick down from the solder tab onto the wiper and create unintended electrical contact. Sometimes a wiper can become bent if the switch is roughly handled or has been bouncing around unprotected in a parts bin.
    Check all the other wipers on the switch while you're in there. Use magnification and a bright light to help you see, because sometimes the problem is really small. Check the switch solder tabs for bridges (unintended contact between tabs).
  13. Nope
    Nope TDPRI Member
    Toronto
    Wiring harness hasn't been touched since it left the factory. I haven't even opened the control chamber.
    I'll open it up later this week and take a look.
    Many thanks for all the suggestions.
  14. AAT65
    Then it’s the bridge volume pot.
    At a guess either it’s faulty or there’s a high-resistance path from the volume pot to ground.
  15. kingvox
    kingvox Tele-Meister
    CT, USA
    Yes, I've had this before. Volume pot all the way down and still substantial signal going to the amp.
    It ended up being a bad pot. Replaced the volume pot and this problem went away.
  16. Audiowonderland
    Audiowonderland Tele-Meister Silver Supporter
    Usa
    You have a bad pot. Its more obvious on the bridge because its hotter and brighter
  17. Audiowonderland
    Usa
    Can't be. The only path from the switch to audible is through the volume pot
  18. Peegoo
    Wyoming panhandle
    You are correct. But there's only one wire carrying signal from the switch to the volume pot, and the volume is working properly for the neck pickup. If the vol pot is defective, it would be leaking neck pickup signal as well as from the bridge pickup.
    That's my rationale for suspecting the switch. But at this stage, anything could be the culprit.
    Geno
  19. Audiowonderland
    Usa
    The capacitance and level of output will vary. The neck pickup may not have enough umph to audible. Hard to say. Assuming standard withing, once you eliminate the impossible.....
  20. Nope
    Nope TDPRI Member
    Toronto
    Photos.
