Brent Hutto
For the first few months I've had my MiM Player Telecaster, I've not messed with the pickup heights. I figured it sounded great to me when I demoed it in the store and for the 99% of my playing that is on the neck pickup it sounds very balanced, warm and smooth to me playing at home every day. I did of course tweak the action/relief/intonation when I brought it home but the pickups are more or less at Fender's usual factory spec.
Lately I've been venturing into the other two switch positions and not entirely pleased with the tone. The middle position was a bit twangy and the bridge pretty shrill but I figured that was some combination of normal Telecaster twang and my own heavy-handed picking. Today it occurred to me that I'd never really tried moving the bridge pickup up or down from those initial starting specs.
Just eyeballing it, the treble side of the bridge looked pretty high. And to my ears, it was the top strings that sounded so biting when I flipped the switch all the way down. All it took was one small nudge of the screwdriver on the treble-side (lowering that side about 1/64") and I noticed two things after the change:
1) The 1st and 2nd strings instantly went out of tune. By a fair bit. Also had to tweak the 3rd string slightly.
2) I no longer needed to back off the Tone knob when switching to the bridge pickup.
So one surprise was how much of an improvement such a small tweak produced. The other was the fact that, apparently, the pickup was pulling the strings out of tune. Is that something you normally see when changing pickup height? Changes in tuning?
I also found I need to re-adjust my intonation on several strings slightly. That might be due to the winter weather moving the neck around a bit, I had not compared harmonics to fretted 12th strings for several months so maybe I was due for an intonation check anyway, nothing to do with the pickups.
Does anyone else find that Fender stock recommendation of around 4 64ths under the treble side of the bridge is a little too high? Mine was actually more like 4-1/2 64ths but still higher than the neck pickup or the bass side of the bridge.
