Bridge pickup cutout does not match cheap Chinese bridge.
Discussion in 'Tele-Technical' started by Bill Allen, Jun 17, 2019.
  1. Bill Allen
    Bill Allen TDPRI Member
    Ontario
    Hello all. IK am very glad I found this site. I am making two telecasters from walnut from a tree cut down in my neighbours yard. I bought the full sized plans online and made the bodies and necks before getting the pickups or bridges. I routed all the cutouts and when I want to place the bridge, the cutout for the bridge pickup did not match the corresponding cutout on the bridge. You can see the difference in the pics. In your esteemed opinions, should I wait till I get the pickups before removing anymore wood so I do not remove too much or should I just extrapolate the pickup recess further towards the neck? Not my first guitar but is my first tele. Thanks in advance for any advice. And YES, I know I should have bough tele3.jpg tele4.jpg t better bridges but they were cheap and nice and black. :)
    nojazzhere likes this.
  2. nojazzhere
    Foat Wuth, Texas
    First thing I think I would do is make some measurements to make sure your plans provide for the correct string length. I have had to do additional routing when changing bridges, but that was always on "factory routed" bodies, and I found the bridges were indeed "off". Make sure your guitar will intonate properly before you do any more to it.
    LutherBurger and Vespa_One like this.
  3. bender66
    on my bike
    Were the plans for a modern or vintage style bridge in their placement of routes?
    Yours looks like a modern, yes?
  4. SPUDCASTER
    Grangeville, Idaho
    BINGO!!
  5. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    bender66 and eallen like this.
  6. bender66
    on my bike
    Wouldn't it be easier to just mount a vintage bridge to the current body? It's ready to go.
  7. Bill Allen
    Ontario
    The plans were from ALS (Australian Luthier Supplies) and it does not refer to the type of bridge, nor did the bridge refer to what it itself is. Silly me assumed they would match. I guess I'll get out my router.
  8. Bill Allen
    Ontario
    And thank you very much for your replies.
    bender66 likes this.
  9. bender66
    on my bike
    Might double check your scale length with your new bridge before routing out more wood.
  10. Bill Allen
    Ontario
    That is the very first thing I did and the reason I am here.
  11. Vizcaster
    Vizcaster Friend of Leo's
    Glen Head, NY
    Hold on a sec, you haven't drilled the string-through holes or bridge screw holes yet. The modern six-saddle american standard type bridge plate has a different location for the pickup rout. Your best bet is to get a different bridge plate - not terribly expensive - just think outside of the "I must use what I already have on hand" box.
    If you were to rout more wood you're very likely to have an exaggerated "butt crack" which is where the rout peeks out from under the bridge plate along the sides.
  12. vanr
    vanr Tele-Afflicted
    AZ
    I would find the proper bridge.
    Matt_Black likes this.
