Bridge Humbucker that Taps Well
Discussion in 'Just Pickups' started by Paul in Colorado, Aug 25, 2019.
  1. Paul in Colorado
    Fort Collins, CO
    I'm rebuilding an Aria Pro II from the '80's that I got cheap. I'm turning it into a bit of a "Jerry-Caster" and I'm going with two Strat style pickups and a bridge humbucker. I'd like to find a humbucker that when tapped blends well with the middle Strat pickup so it sounds somewhat like a Strat in the "4" position.
    Here's a picture as it now sits. It's going to get a swimming pool rout and a brass plate to mount the pickups as the routs for the original pickups are odd sized.
    radiocaster and Teleterr like this.
  2. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    I ve yet to find a Gibson style HB that I like w Strat p-ups, split or otherwise. W me it's the coil shapes not jibbing and maybe the frequency response curves as well. Of course they now make those dual Strat coils HBs. Rio Grande etc. So hopefully someone who has one will chime in. If you want a Gibsonesqe tone for the HB tho , the good old SD SH-14 when split has a similar output level, but of course a totally different tone , like a Gibson , but an octave lower. Duncan also makes a HB w a '59 coil and a SH-14 coil, which would give you more options.
    Then again why not a Strat Bridge and Middle right next to each other from a set where 2 and 4 positions are hum cancelling ? Since it's a pool rout and if Strat sound is ok.
    BTW you, I, and lots of others would number Neck one, but Fender goes w Bridge as one. I think you mean 2 not 4.
    Paul in Colorado likes this.
  3. steve v
    steve v Tele-Holic
    Albany, NY
    Fralin Unbuckers seem to get high marks for coil splitting. I had great luck with a GFS dual lipstick humbucker, the split works great.
    As an aside, I orient bridge humbuckers so the always-on coil is forward, towards the neck. I think it sounds better that way. The change in volume doesn't seem as drastic when you split
  4. Mincer
    Mincer Tele-Holic
    Tampa Bay Area
    Oh! I think you mean split. Tapping is a different process, and rarely seen in humbuckers. I'd say the 59/Custom Hybrid, which has a great split sound, but on full, it still has dynamics and can do anything from vintage to modern music.
    Paul in Colorado and Teleterr like this.
  5. Dismalhead
    Sacramento, California
    I had a DiMarzio PAF Pro that I put in an old Ibanez Roadstar a few years back. It sounded beautiful split and blended with the middle pickup.
  6. Potatocaster
    Potatocaster TDPRI Member
    Fayetteville, Arkansas
    A lot of a good tapping of a humbucker can be managed by a resistor in line like PRS does.
    Edit: or splitting to be accurate.
  7. Teleterr
    Lewes De.
    Yeah, thats the other one I mentioned.
  8. brookdalebill
    Austin, Tx
    I like Seymour Duncan Stag-Mags.
    They sound great tapped/split or not.
    Fairly cheap, too!
    bgmacaw likes this.
  9. Teleterr
    Lewes De.
    Are those tall Strat style coils ?
  10. brookdalebill
    Austin, Tx
    They’re just two regular staggered magnet coils wound as a humbucker,
    When split, they sound like a good, strong Strat pickup.
    The coils are not taller or a different size than standard.
    They are vastly superior sounding to most split/tapped
    humbuckers, IMO.
    bgmacaw and Teleterr like this.
  11. Paul in Colorado
    Fort Collins, CO
    Yes, split, not tapped. Thanks for the suggestions. Keep 'em coming.
  12. Teleterr
    Lewes De.
    Are you looking for a trad tone for the HB alone or don't care ?
  13. gitold
    gitold Friend of Leo's
    Greeley Co.
    Are you going to route the hole for a full size humbucker or use a stacked one?
  14. Paul in Colorado
    Fort Collins, CO
    Ideally, I'm trying to get both a good HB tone and a single coil with middle pickup sound. Maybe that's asking too much?
  15. Paul in Colorado
    Fort Collins, CO
    Swimming pool route with a brass plate on the top to attach the pickups. Something like this, but single coil in the middle and no effects loop/preamp.
  16. gitold
    Greeley Co.
    Seymour Duncan Pearly gates then. Great bright humbucker and splits real nicely.
