bridge for squier japan
Discussion in 'Tele-Technical' started by aj55, Mar 18, 2021.
  1. aj55
    aj55 TDPRI Member
    Netherlands
    Dear all,
    I am lucky to own a E-series Squier in perfect condition. I would like however to exchange the bridge for a 3-saddle bridge like the one I have in my '99 Fender mij Tele. Both are toploader. See pics:
    Problem is they both are mounted with 3 screws and all I can find is with 4 screws.
    Does anybody know where to find such a bridge?
    Cheers, Arnold
  2. SbS
    SbS Tele-Holic Silver Supporter
    Finland
  3. aj55
    aj55 TDPRI Member
    Netherlands
    Thanks! Looks like it, although no top-loader. But I suppose I could drill those holes myself ;-)
  4. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    ED2E3766-FC49-473F-A70B-2B9DFDFF60F3.jpeg Those Kluson bridges have a hybrid “vintage ashtray-lip / newer and longer US and Squier standard” design and have string through holes made for those Standard Teles that you don’t need for that top loader Tele. They have their place for owners of newer Standard Teles who want those vintage style features.
    If you really want a flat (side lip-less) and thicker bridge like your second picture shows, you might want to investigate using a bridge like those made after around 2000 for Squiers that have six non-offset saddles. Used or eBay. You would still need to three drill holes for the three saddles’ intonation adjusting screws, but you can use the six saddles’ mounting holes as your toploading string through holes. I have a couple I can photograph...
  5. yegbert
    Maryland (US)
    The top 2 plates are from string through Squiers. The bottom is a vintage style dual loader I used for illustration purposes. The top two would only need 3 holes drilled between each of the E-A, D-G, and B-E “pairs” of saddle mounting holes, to support a vintage-style 3-saddle set. And the old 6-saddle hole are positioned good for top loading.
    Note that if using vintage style 3 saddles with these plates as such, you are likely to need to obtain longer than vintage normal intonation screws and springs.
    if you get someone’s old bridge plate from a top loader-only Tele (some early Affinitys), you wouldn’t have any of these Squier Standard string through holes.
  6. dpang2836
    dpang2836 Tele-Meister
    Post Falls Idaho
    Do not Alter your Body, which includes new Bridge Holes! Take your time and find the right one! Kluson is nice and I have seen a couple others. Top load only might be a Problem though?
  7. yegbert
    Maryland (US)
  8. SixStringSlinger
    SixStringSlinger Friend of Leo's
    Space
  9. aj55
    aj55 TDPRI Member
    Netherlands
    Thanks all!
    That last one really looks the one though :)
    Unfortunately it will be really expensive by the time it gets to the Netherlands (freight, tax, duty)......
