JohnnyThul
Hi all,
Yes, we all know the feeling, one project isn't enough, and while I am at 3 at the moment, why not continue on a 4th? Because I (think I) can!
I want a double neck. For no other reason, than just to have it. No sense at all. I started a few years ago by making the body and the neck blanks (multiple pieces of maple and stairstep mahogany).
This is the body ( 2 piece stairstep mahogany and 2 piece flame maple top) so far where I refined the shape a little last week:
Pics of the neck blanks I will have to make later.
I made the 12 string headstock template on the weekend and I am pretty much good to go regarding the necks now.
But, there is a tiny detail I have to ask you about: the switching/wiring of the beast.
So, dumb as I am, I do not have exact records as to where I made chambers in the body (yeah, I know....). In the worst case, I won't be able to put a toggle between the necks as I may have forgotten the chamber there.
So, that leaves me with placing the toggle for the necks at the lower part of the body. No problem. BUT: I would like to avoid to have zillions of switches and pots on the guitar, I hate the look of it.
Would it be possible to have only one master volume and one master tone working for both necks? So only having to use 2 potis all in all? And if so (now we're getting started...), is there an option of including as blend pot for the neck pickup of the 12 string neck, which controls a coil of the neck humbucker (Bluesbucker type) ?
That would mean in the end: 1 toggle for selecting the necks, one toggle per neck to select pickups (2 humbuckers per neck), 1 Master Volume, 1 Master Tone, 1 Blend pot for a coil of the neck humbucker of the 12 string.
I am really not good at electronics, switching and all that. If someone with more insight could tell me, if a configuration like that would work, that would help me quite a bit at this stage of the built, as I have to make a choice regarding the 6 string bridge (TOM + STP or wraparound).
Unfortunately not so much pics so far, will have more by the weekend, promised!
Best regards
Jonas
Best regards
Jonas
