Brass bushings on split shaft pots?
Discussion in 'Other T-Types and Partscasters' started by AbleMob, Jul 30, 2021.
  1. AbleMob
    AbleMob TDPRI Member
    Central Jersey
    Has anyone tried those adapter bushings for pots that allow you to use knobs meant for solid shaft? There is only about .35 mm difference in the diameter of the split shaft and the solid one, and I have a hard time seeing the wall thickness of the bushing being that thin. This would solve a lot of issues in my builds because of the difficulties sometimes in finding solid shaft pots that match the specs I like. I prefer the set screw type knobs, and there is also the issue of the fine or coarse thread spline compatibility with a lot of the push on knobs
    Boreas and Timbresmith1 like this.
  2. stratisfied
    stratisfied Tele-Afflicted
    Midwest
    If you mean knobs with a set screw, I just line the set screw up with the slot of the shaft and tighten. That spreads the split shaft slightly and wedges the shaft tight to the knob. No adaptor needed.
    aging_rocker and Coffeemutt like this.
  3. Ricky D.
    Ricky D. Doctor of Teleocity
    Marion, VA
    The adapters from Allparts work well for me. Better than trying to film flam it.
    Buckocaster51 and Timbresmith1 like this.
  4. Timbresmith1
    Timbresmith1 Tele-Afflicted
    Central TX
    Used to use them frequently. They work great.
  5. jfgesquire
    jfgesquire Friend of Leo's
    Lake View
    The brass bushings use 1/4" tubing that is .17mm thick and they work perfectly in the correct application.
    But I have had split shaft pots that were too big for the bushings, or maybe it was set screw knobs that were smaller than 1/4", can't remember which.
    AbleMob likes this.
  6. dogmeat
    dogmeat Friend of Leo's
    Alaska
    I put a strip of aluminum in the slot & crank down the allen screw. it allows me to position the screw where ever I want
  7. Peegoo
    Peegoo Poster Extraordinaire
    Challenging Definitions of Sin
    I use diagonal cutters to snip a little square from a 1mm thick guitar pick.
    The little square fits snugly into the slot and allows me to place the knob's set screw anywhere on the split shaft with no concerns about the screw breaking one of the split halves.
  8. SixStringSlinger
    SixStringSlinger Friend of Leo's
    Space
    They work fine for me so long as I don't tighten the set screw too much (and if you're tightening the set screw enough to cause problems with the little brass adapters, you're tightening the set screw too much, period).
    One interesting problem I had using new split-shaft pots on my Reverend (and keeping the original knobs, which were on solid-shaft pots) was that the brass adapter was too short to reach the set screw on those particular knobs. I fixed that by just stacking two adapters per pot. That and making sure the knobs didn't sit right on the body worked like a charm.
  9. Tenderfoot
    Tenderfoot Tele-Afflicted
    Katy, TX
    From personal experience, they work (really not much more I can add).
    Ron C likes this.
  10. AbleMob
    Central Jersey
    Unfortunately that makes them wobble. The set screw pushes the knob to one side of the shaft, making it eccentric.
    Phrygian77 likes this.
  11. AbleMob
    Central Jersey
    Thank You-the caliper photo is very helpful and answered my question perfectly!
  12. stratisfied
    Midwest
    Sure. If you mount a dial indicator you might even be able to measure the run-out you imagine is there.
  13. AbleMob
    Central Jersey
    Thanks Stratisfied with your expertise on eccenctric set screw knobs on split shaft pots and also with your incredible insights on 22 fret vs. 21 fret necks! I so look forward to your wisdom as you troll my future posts! Best.
  14. Boreas
    Boreas Poster Extraordinaire Silver Supporter
    Adirondack Coast, NY
    I use them quite a bit. Work well. I line the set screw up with the split so the screw indents the bushing a little. This keeps it from slipping, and you don't have to over-tighten.
    AbleMob likes this.
  15. stratisfied
    Midwest
    I'll try t
    No problem. I'll try to keep 'em coming but it's tough being the voice of reason sometimes.
