Brass amp chassis?
Discussion in 'Amp Central Station' started by Dsav54, Mar 29, 2020.
  1. Dsav54
    Dsav54 TDPRI Member
    Ri
    Hey there,
    I'm starting a 6g15 reverb unit build, and planning on building the chassis and cab from scratch. I have a bit of brass sheet metal (various thicknesses) that'd I'd love to put to use.
    Any thoughts on using brass? Everything I've found says it's more conductive than steel, but that's all I could find.
    Thanks!
    Dave
  2. printer2
    There is no reason you can not use it. You can solder the box together if you want.
  3. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    No intrinsic objections. You'll need to be mindful of the structural strength needed, and the visible areas will need a finish to maintain the appearance.
    Wally likes this.
  4. Ringo
    Ringo Poster Extraordinaire Silver Supporter
    Memphis TN
    I had an older Ampeg combo amp a few years ago, wasn't working, I sold it for parts, the chassis was copper!
  5. Wally
    I have seen quite a few copper-plated chassi, but I have seen solid copper chassi only in the 1964 Rickenbacker amps I have owned...a B-16 Supersonic and this B9A.....
  6. corliss1
    Lansing, MI
    Weren't the early Champs solid copper?
  7. Wally
  8. corliss1
    Lansing, MI
    I'm doing everything from my work computer at the moment, but I worked on a 49 or 50 champ and took lots of photos. I'll see if I can get to them at some point...
  9. DuckDodgers
    DuckDodgers Tele-Meister Silver Supporter
    Dee-troit City
    Brass is more conductive than steel, but with proper construction techniques, like single point grounds, it would make no real difference one way or the other.
    Tim S likes this.
  10. Dsav54
    Dsav54 TDPRI Member
    Ri
    Awesome! Thanks for the responses every one! :)
  11. bparnell57
    bparnell57 Poster Extraordinaire
    Philadelphia, PA
    Would work fine, but would need to be thicker for equivalent resistance to bending.
    Wally likes this.
  12. tubegeek
    tubegeek Tele-Afflicted
    Brooklyn, NY
    I've gutted a console amp that had a lovely copper chassis, I think it was a Motorola - maybe a Magnavox. One of the M's.
    Brass will be nice for a guitar amp, you could even nitro lacquer it when you're done.
