how about this instead?
https://www.boss.info/us/products/odb-3/
from the keeley od3 mods i found at stompboxzone
The next mod is a simple one as well (catching on to the theme yet?). Remove R14 or put it on a toggle switch. The distortion level increases by a large amount. Not quite your cup of tea? Do you have some oscillations? Well, reduce instead of removing it. Change the resistor value to somewhere between 2.2K and 4.7K. You get about the same effect and the unit will be a bit more stable.
1k makes it like an OCD with good amount of mids
1.6k is like a modern superoverdrive/ts9
all in my opinion
probably what the OP was hearing was the high mids that the od3 was pushing as pointed out by .11Gauge in an old post as compared to the mids the bd2 had.
.11 Gauge: which would be a better mod: changing the D10,D11 to 1n400x or D6,D7 to 1n4148? i understand each set are the 2 gain stages of the od3. thanks for your patience and sharing your kno
Just joined the forum and checking it outprobably what the OP was hearing was the high mids that the od3 was pushing as pointed out by .11Gauge in an old post as compared to the mids the bd2 had.
.11 Gauge: which would be a better mod: changing the D10,D11 to 1n400x or D6,D7 to 1n4148? i understand each set are the 2 gain stages of the od3. thanks for your patience and sharing your knowledge.
