generic202
Just enjoy your Katana. None of this stuff really matters anyway.
But if you want the nitty gritty... some people think Katana is a solid-state amp like JC120. It's not.
Boss Katanas (50, 100, Go, etc) get their amp models (clean, crunch, lead, etc) digitally. We don't even need to go into effects. There is no solid-state analog preamp for amp models like Quilter or BluGuitar.
(With the only exception being Katana Mini which is all analog SS from input jack to the speaker except the delay effect)
Here is a service manual of Katana 50 MKII:
www.manualslib.com
If you care to look at it (p16-17), this is the entire guitar signal chain internally:
Input jack --> input buffer --> signal splits into low and high --> both to ADC --> ESC2 DSP chip --> DAC --> Aux-In/Phone Out circuit --> attenuation circuit --> SS power amp chip --> speaker (and feedback to power amp).
Through out the entire signal chain, there is no analog solid-state preamp circuit for amp models. All amp selection and its sounds are generated in the digital realm.
Yes, Katana has a solid-state power amplifier to drive the speaker. But that's all it does. They work similar to Fender Tonemaster amps. Katana's SS power amp may impart a small sonic footprint but it's mostly there to cleanly amplify what's coming in.
I don't mind being corrected when I'm wrong... but that service manual is pretty clear.
BTW, Katana MKII patches can be used on the new Katana Go because they all use the same digital amp models.
Block Diagram - Roland BOSS KATANA-50 Mk II Service Notes [Page 16]
Roland BOSS KATANA-50 Mk II Manual Online: Block Diagram. fig.block-50.eps@L 16...
