BOSS CS3 - is it noisy at low volume?
Discussion in 'The Stomp Box' started by VerySlowHand, Feb 28, 2020.
  1. VerySlowHand
    VerySlowHand Tele-Holic
    Worcestershire, England
    I'm after a compressor and have read that the CS3 is noisy, but with little further information. Is that just at higher gain, or higher volumes, or is it noisy all the time?
    The BOSS is the budget option. Other thoughts are a TC E Hypergravity or Keeley Compressor Plus.
    I don't want too much colour from it, more to give that 3D sort of thing, rather than the squishy stuff... if that makes any sense - suggestions welcome.
    Thanks.
  2. MatchlessMan
    MatchlessMan Tele-Holic
    Wiltshire UK
  3. Switchy
    Switchy Tele-Holic
    Arizona
    The CS-3 is noisey if you set the sustain at a high level. But the truth is, you don't normally need to set the sustain so high.
    I wouldn't call the Boss CS-3 the "budget" option. It's still about $50 bucks used.
    The Joyo Dyna Comp is the budget option, but having owned one, I didn't feel it did anything, literally. The Boss works, and you can tell it works.
  4. schenkadere
    schenkadere Friend of Leo's
    NY
    Diamond Compressor or Mooer Yellow Comp. I have the Mooer and it's awesome. Although what you describe is rather objective, I think this will give you what you desire.
    RetroTeleRod likes this.
  5. Junkyard Dog
    Junkyard Dog Tele-Afflicted
    My experience is similar to Switchy's. If you crank the sustain all the way up, then you'll hear some hiss. But at normally used settings...no noise.
  6. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    ^^^ This. I actually own a Diamond, a Mooer and a Boss CS-3. The Diamond is the quietest, followed by the Yellow Comp and then the Boss. As others have noted though, the CS-3 isn't bad at lower sustain settings. Haven't tried one, but I understand that the newer Boss CP-1X is very quiet.
    Optical comps like the Diamond and the Yellow Comp don't color your sound as much as other compressors might. In fact I'm currently using my Mooer on my acoustic board. It and the Diamond are both great at tone sweetening.
  7. dlew919
    dlew919 Poster Extraordinaire
    Sydney
    Compressors don’t make noise. They compress the noise that’s already in the signal making it louder at the right frequency.
  8. dswo
    dswo Tele-Holic
    East Carolina
    The CP-1X is noticeably quieter than my Xotic SP.
