Boothill 5E3 build
Discussion in 'Shock Brother's DIY Amps' started by CtoshiningC, Jul 22, 2019.
  1. CtoshiningC
    CtoshiningC TDPRI Member
    Vancouver, BC
    Hello all!
    I put a boothill 5F1 kit together a few years back and, well...you know how it goes.
    I've started to put this 5E3 kit together. I've got much of the components laid out on the board. Still need to add more leads leads and under-board connections. Got ahead of myself and soldered a few things on.
    Hopefully I've got everything in the right place so far. Thanks for looking!
  2. tubedood
    tubedood Tele-Meister
    Orlando
    I have heard great things about the Boothill kits, Keep up the good work!
  3. King Fan
    Salt Lake City
    Can't have too many 5e3s in the world! Have fun and share pics...
    KellyWalrus likes this.
  4. CtoshiningC
    Vancouver, BC
    I've been using Rob's wonderful site and 5e3 layout. There, the HV center tap is routed to the power amp filter caps and then everything is sent to ground. Is there a benefit to running the HV CT there, or can it just be sent to the same ground point that first set of filter caps uses?
  5. King Fan
    Salt Lake City
    Rob says:
    robrob and CtoshiningC like this.
  6. CtoshiningC
    Vancouver, BC
    Guess I should read more! Thanks
  7. CtoshiningC
    Vancouver, BC
    Another one - on the tube side, the cathode bypass cap/power tube cathode are routed first to V4 then V3 (both on pin 8). With my board and chassis, V3 is closer and more convenient to hit first. Do the order of these connections matter? I'd guess not as they go to ground...but would like to check
  8. robrob
    United States
    The order doesn't matter.
    CtoshiningC likes this.
  9. CtoshiningC
    Vancouver, BC
    Another step closer! Got the leads in and trimmed. Any issues that need addressed before continuing?
    Thanks for looking!
  10. CtoshiningC
    Vancouver, BC
    I decided to put this 5E3 chassis into a head cabinet. I'd built a 2x10 cabinet a while ago for my 5F1 and figured going with a head cab would be a flexible option. Maybe even give me an excuse to build a 1x12 speaker cab in the future.
    Used a router jig and went with half-blind DOVETAILS IN 3/4" pine. Channeled out a slot (with a lip in the top and bottom) for the front panels using a table saw. Used a forstner bit to get a nice corner radius for the chassis cutout. 20190225_153127.jpg
    Used a straight edge to router out the rest of the chassis cutout and used a round-over bit on all the edges.
    Used some 3/8" baltic birch ply for the front and rear panels. Put a small round-over on the back panel cutouts.
    When building my 5F1, I had seen a picture of a transitional era champ. A narrow panel version with black tolex, and was quite enamoured with the look. I never did tolex the champ, but decided upon that look for this build. Watched the Uncle Doug tolexing videos a bunch of times and got to it.
    Fender-style straight corner cuts. Some turned out better than others.
    Used an old-style handle, some stainless steel hardware. When fastening the grill cloth, I found using a sheet metal seamer to pull the edges tight a huge help. Made it easier to pull a section tight and keep it straight and even. And here we are, ready for a finished chassis.
    jtcnj, zephyrR1, FenderLover and 7 others like this.
  11. D'tar
    D'tar Friend of Leo's
    WNY
    Your board looks fine and your cabinet looks fantastic!!!
  12. BigDaddy23
    BigDaddy23 Tele-Holic
    Fantastic stuff! Well done!!
    What's your plan to route the speaker and power cables out of the cabinet? Through the cutouts, perhaps a jackplate?
    SacDAve likes this.
  13. CtoshiningC
    Vancouver, BC
    Thanks.
    The plan was to exit through the cut-outs. I'd imagine one would need to be mindful of the cables and the tubes.
  14. King Fan
    Salt Lake City
    That cab looks insanely great. Good job.
    Sent from my iPad using Tapatalk
  15. Syrinx
    Syrinx Tele-Holic
    Champaign illinois
    good idea on the metal seamer-will likely do that next time I recover something.
  16. CtoshiningC
    Vancouver, BC
    Any tips on how to get the switches to stay on tight? Do folks use a lock-washer here?
    Terickson likes this.
  17. robtking
    robtking TDPRI Member
    Dublin
    Your cab looks fantastic - well done! It's almost a shame to cover over the excellent woodwork!
  18. CtoshiningC
    Vancouver, BC
    Some more progress...baby steps.
    Got the PT and OT mounted. I'm using a Hammond 290BX and 1760E.
    Mounted the board after checking (again) resistor values, leads etc.
    Finding correctly sized star washers around these parts proved as difficult as finding a unicorn. Ended up with some fibre washers to mount the switches. Sinched up all the other pots, fuses, jacks etc. nice and tight.
    Drilled a hole to add a ground point rather than use a PT bolt. Lock-washered a piece of terminal strip there. Have the HV center tap going to the first filter cap, then to ground.
    Mounting jacks seems to be a tight squeeze here with the turret board. I ended up snipping off the un-used sleeve tabs on the secondary input jacks to buy some breathing room. Still need to solder these connections.
  19. CtoshiningC
    Vancouver, BC
    Wired up the PT to the rectifier socket. Added 1N4007 diodes between pins 3+4, and 5+6.
    Wired up the pots and connected them to the ground bus. In this picture, that 56k resistor for the PT tail has an actual value of 67k. I understand 56k carbon comp values are notoriously out of whack. Hopefully mine isn't too far out?
    Paul-T likes this.
  20. CtoshiningC
    Vancouver, BC
    Got the tube sockets wired up.
    V1 and V2. Added the NFB mod in.
    Tight squeeze on V3 and V4. My PT (Hammond 290BX) doesn't have a 6.3v centre tap. I used Rob's artificial centre tap here with two 1/2W 100ohm resistors from pins 2 and 7 to ground at pin 8. Also added 3W 470ohm screen resistors from pins 1 to 4 and moved the connection from B+2 to pin 1.
    I'm going to omit the standby switch connection, wiring pin 8 (B+) on V5 to B+1.
    Only a few more steps to go - wiring up the speaker output, power, switch and fuse.
    Mr Ridesglide likes this.
