Boot Hill 5e3 build
Discussion in 'Shock Brother's DIY Amps' started by notdan, Nov 3, 2019.
  1. notdan
    notdan TDPRI Member
    KC
    Starting on a boot hill 5e3 build! Have a bee box for cab and working on some wiring. I’m following along the stewmac 5e3 guide which has been super helpful. Couple questions so far (see attached image):
    1. What is the L shape thing for?
    2. Where do I use the crimp connections?
    3. Where do I use these plastic bolts?
    Thanks for the help!
    KellyWalrus likes this.
  2. notdan
    notdan TDPRI Member
    KC
    Also, before I trim these and solder, things looking ok so far?
  3. Nickfl
    Nickfl Tele-Afflicted
    The crimp spade connectors are for the speaker. The crimp ring terminals are for your safety ground (the power cord green wire) and your circuit ground reference (power transformer high voltage secondary center tap and filter cap ground usually).
    I believe those plastic bolts are for mounting your circuit board to the chassis.
    The L shaped thing is a solder terminal that bolts to the chassis somewhere and allows you to have a solid place to make a soldered connection, I'm not sure what it is for in your kit though. I seem to recall that @hackworth1 includes a layout with the kits, take a look and see if you can find it on there, if not maybe he'll chime in and clear it up.
    I don't see any obvious mistakes on your board, but I'm not as good at spotting that sort of thing as some others here.
    King Fan and notdan like this.
  4. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    ^^^ what Nick said.
    The crimp-on connectors for the speaker are kinda optional -- some folks just solder the wires to the speaker lugs.
    OTOH the crimp-on ring connectors are UL and industry best practice. You'll need a big (but cheap) wire crimper from the hardware store. Strongly crimped joints are considered better than soldered, because stronger mechanically and better metallic union at the molecular level. Despite this, I solder over my crimps just for grins. Because shiny...
    Re layouts, the Stew-Mac instructions are very detailed, but they may contain a few unclear or just wrong ideas. It's worth getting the layout Dave provides or recommends, and then repeatedly comparing that to the modern gold standard (Rob's latest at robrobinette.com). Then also compare as you build to the original Fender 5e3 layout (Rob shows one with the circuit path and component functions ID'd). And then *also* compare your build step-by-step to the schematic, which shows the 'electron's view' of the circuit and is therefore actually the best map.
    For pictures, post a ton for us and for your own later reference. I'm also not great at spotting errors, but you'll help us and yourself if you can post full size, well-lit (two lamps minimum) pics *inline* in your posts so they'll blow up. You can drag-drop the file into the post-composition box, or use the 'Upload a File' button. And a small item -- make 'em landscape / horizontal and ideally with the filter caps to the left on any overview or board shots.
    El Tele Lobo and notdan like this.
  5. notdan
    notdan TDPRI Member
    KC
    Thanks for that! Lots more pics and questions to follow. For now working on the cabinet. Can I fill small cracks with drywall compound without worrying about it vibrating into dust and crumbs? Will be under tweed so not worried about looks but have a few low points and cracks between the joints and fascia that need filled.
  6. notdan
    notdan TDPRI Member
    KC
    Also see first pic again. The blue white wire... is that the correct stuff to be using? I expected it to be thicker given the 300-600 volts. I also have red white striped I think and black, same size. When to use which? There is also a bare wire, I’m assuming I use that for the ground buses on the robrob plan? Then there is a thicker maybe green wire, any idea when to use that one? (can post pics later if that’s super unclear).
  7. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Why not get you some wood putty eh?
    Should be some printing on the wire insulation informing of the specs. AWG22 wire rated for 600V isn't very thick. The thicker green wire is possible AWG20 for the heaters, a little thicker because of the extra current that flows there. The bare wire would likely be either bus wire if it's thick and sturdy, or jumper wire if it's real thin and bendy.
  8. stepvan
    stepvan Tele-Meister Ad Free Member
    amherst
    If the cracks are going to be covered by the tweed so looks are not important, any kind of filler i.e. polyester body filler,wood filler, glazing compound etc. Could be used. Glazing compound comes premixed in a tube and is available at any store selling autobody stuff. Providing you are talking about small cracks that's what I'd use. Spreads easy, dries fast and sends easy
  9. notdan
    notdan TDPRI Member
    KC
    A bit more progress. Does it matter which direction the transformers are mounted? What are the clips around the power and rectifier tubes for? I think I got the sockets in the right direction based on some pics but if that looks wrong let me know. Thanks so much for the help so far!
    Also, if you know of any threads or pages that have some really good pics of completed wiring let me know or good build tips. I’ve found some on here and am reading what I can find but any specific good resources you know of I’d love to see more.
    1FA8BA1F-E1B1-452C-9ABB-A52FEAFB361D.jpeg 7625CFCA-5305-49A7-8876-98A1D761ED01.jpeg 84207A99-3CAD-4775-9E8D-5C311E1AB91E.jpeg A9DCE16A-A855-4EC6-AD85-62A1FEE0CC3B.jpeg 1D5A8D14-956D-4B78-B5D0-269A49FBB883.jpeg
    Pick_n_Strum and KellyWalrus like this.
  10. Edvin
    Edvin TDPRI Member
    Norway
    No matter witch way you choose to mount the transformers as long as you get the wiring correct.
    The clips is to secure the tubes so they dont fall out due to vibrations.
  11. muchxs
    muchxs Doctor of Teleocity
    New England
    Dave sent me a couple of the first Boothill kits a few years ago. I guess he was hoping I'd do a build thread here. I'm not supposed to use the TDPRI to promote my amps and for the most part I'm not going to promote anyone else's amps. I built them up and sent them back. I used as many of the supplied parts as I could and wired them up using best practices and tricks learned by building a room full of these things.
    Try soldering a few junctions.
    It's supposed to be a ground point. That's what it was used for in the two Boothill kits I recently refurbished
    NOWHERE.
    Crimped connections have no place in a guitar amp, not unless you crimp and solder them. To that end poke your soldering iron through the ring of the ring terminals. Slide the plastic sleeve off when it gets hot. Then crimp and solder the connectors.
    "Anything that can shake loose will shake loose sooner or later."
    Those are to mount the circuit board.
    A better way to do it is to use threaded standoffs mounted to the chassis with machine screws. Use shorter plastic bolts (machine screws) to mount the board to the standoffs.
    Use Bondo. That's polyester automotive body filler. Home Depot stocks it back by the glue.
  12. King Fan
    Salt Lake City
  13. notdan
    notdan TDPRI Member
    KC
    Thanks for the pics thread, just what I was looking for. Here is today’s progress.
    B305D1D7-872F-4C6A-9170-D9113E587531.jpeg DC6DF5FA-ACC9-464E-8BDF-49DCAE302404.jpeg
  14. notdan
    notdan TDPRI Member
    KC
    1F5B20A4-315B-47FF-A56F-554B2D76890E.jpeg 6727A810-BC87-479F-A5E0-15A2602C4F73.jpeg
    Prophetsnake likes this.
  15. Edvin
    Edvin TDPRI Member
    Norway
    I woulda moved the live wire for the fuse to the center of the fuse holder.
    Just for safety.
    Now you can get shocked when you change a fuse.
  16. notdan
    notdan TDPRI Member
    KC
    Wire moved, thanks for that! How much contact cement do I need to tweed this thing? 1 pint? More?
  17. King Fan
    Salt Lake City
    Meant to mention, wire nuts are considered bad juju in guitar amps. Vibration anyone? Look up "Western Electric splice" and shrink wrap, or just solder both ends to a nice (isolated) tag strip lug.
    Prophetsnake and KellyWalrus like this.
  18. notdan
    notdan TDPRI Member
    KC
    A3CF3A4A-D86A-40E4-9E13-59C161B85698.jpeg 454424BF-0C84-4DD2-A0EE-067D2040F2ED.jpeg 21ACD93C-9716-4C04-B29D-09F376F34710.jpeg 86909E25-4F6B-477B-A82D-D7698195E45B.jpeg Progress on the cabinet. This is from a bee box. Realized I put the hole on the wrong side. Wouldn’t think that would make much difference so I plan to leave it but annoys me knowing it’s there. I decided to angle the front which made for extra work but turned out ok. Chiseled the bee box handles into a square and glued a board in to fill the gaps. I think if I did this again I’d probably skip the bee box and buy some pine and just drill holes and use dowels, but I am happy with this result too. I’m realizing the cabinet that started out as a $15 bee box is going to cost close to what it would take to buy one professionally made after the bee box plywood tweed grill cloth tweed glue shellac alcohol screws tee nuts handle feet wood filler etc etc. Definitely over $100. Doing a second one would be much cheaper since I have the supplies. That said, I think if the tweed turns out ok I’ll be more satisfied that I built the whole thing so we will see.
  19. notdan
    notdan TDPRI Member
    KC
    Progress. For some reason I started following the mojotone guide (straight across) for the fil wires instead of the boot hill recommended way of to the edge of the chassis away from other wires. Wishing I wouldn’t have done that. Do you think what I have will work ok or should I redo those? 8A079739-160B-48A1-BB61-CF86F591B3D7.jpeg B0D82AE8-165F-41D2-9F40-906F5A01C0BC.jpeg AD2E2E9D-A855-460E-BF3D-2CA941107023.jpeg 5C70AE66-1797-4069-9AF0-B33307A9A37A.jpeg 40463D09-6A94-43CE-B4DB-B2F9585A2723.jpeg 699F6F43-187B-4118-87CF-BE65196877D1.jpeg ABE74C65-5FDB-4ED6-ABDE-F5F824FFBDE3.jpeg 6041ED6D-CEEF-4D85-B39A-695C966B6800.jpeg 4C1B19D9-7AB7-483C-924F-AC695ECE2C1F.jpeg
  20. BobSmith
    BobSmith Tele-Meister
    San Jose,CA
    This looks like a top-down approach to building the 5e3 (starting with front back panel mounted components). I personally like a bottom-up approach (start with grounds, turret board the panel mounts. I just think it makes it easier to assemble.
    In particular, it can be difficult otherwise to ensue there is enough clearance around the output socket connections. Yours are flattened out which makes it a bit easier. Additionally, just looking at this, I wonder if you won’t need to change the orientation of your lamp holder to make room. Remember this will be flexing when changing bulbs. You wouldn’t want to make unwanted contact with the board components. Just my observation anyway.
    King Fan likes this.
