Boosting into a boost?
Discussion in 'The Stomp Box' started by Hendrixlvr, Mar 3, 2021.
  1. Hendrixlvr
    Hendrixlvr Tele-Holic
    Mississauga, Ontario Canada
    Anyone ever tried using 2 boost pedals to achieve overdrive on a clean amp? Like having a dimed clean boost running into another clean boost. The dimed one to overdrive the clean one and the clean one to set the overall volume of that makes sense to anyone LOL
  2. blue17
    blue17 Tele-Meister
    Washington, DC
    I know some people use a boost at the beginning of a signal chain to raise the level (or to make up for low output pickups), and then one at the end of the signal chain after the other effects to just boost the signal into the amp, if that makes sense. Both of those options would drive the amp to a certain extend. When dealing with volume, there isn't really a way to avoid the amp breaking up past a certain volume if the headroom isn't there.
    But, no I haven't heard of people using two clean boosts consecutively.
    Hendrixlvr likes this.
  3. Blrfl
    Blrfl Tele-Afflicted
    Northern Virginia
    What you'd be doing with that is essentially a home-brewed OD/distortion/dirt/whatever pedal made up of two other pedals. The first one would drive the second into whatever behavior it's going to exhibit when its input is driven too hard.
    A lot of great things have come from experimentation; I say go for it.
  4. Killing Floor
    Killing Floor Tele-Afflicted
    Austin, TX
    Why don’t you just make 10 louder and make 10 be the top number and make that a little louder?
    Mouth, pi, Marc Morfei and 6 others like this.
  5. Willie Johnson
    Willie Johnson Tele-Holic
    Chicagoland
    I'm sorta doing this with my current rig:
    Guitar>BD-2>GE7>PRRI input 1 in>PRRI input 2 out>always-on FBM1>always-on T Rex Fat Shuga boost/reverb>Silverface Princeton input 1 in.
    So when I hit the BD2 (gain off, level around 1 o'clock) and/or the GE7 (main slider a bit above 50%) going into the PRRI, they're also boosting the pedals daisy chained into the path to the second amp, adding some grit and coloration, but with a volume boost to both amps that are close to equal--SF Princeton jumps out a little more.
  6. 65 Champ Amp
    65 Champ Amp Tele-Afflicted
    Illinois-Wisconsin line
    It works.
    Just be careful of a volume blast if you have one cranked and fail to engage the other.
    I would set their outputs the same.
    Use your guitar volume.
    Boosts and guitar volume knobs interact superbly.
    uriah1 likes this.
  7. 65 Champ Amp
    Some boosts have a gain knob~ 4 knob Spark Booster, or Fulltone Fat Boost, for example. Their circuits provide a very light range of overdrive, but really respond to a boost in front of them.
    uriah1 likes this.
  8. Edgar Allan Presley
    Edgar Allan Presley Friend of Leo's
    Colorado
    If you're overdriving the clean boost, can you still call it "clean boost"? I use a Prince of Tone in its "boost" setting, but I'm using it as a low-gain overdrive. I used to have a Zvex Super Duper 2 in 1, which is this concept of driving a boost with a boost and making it clip. That pedal is painfully shrill into a Fender amp.
  9. GuitarsBuicks
    GuitarsBuicks Tele-Holic
    Somewhere between here and there
    I love doing this. The only problem is that it tends to get quite loud. I have two boost pedals. It sounds great when you put it into something like an SRRI...like I said it can be very loud...especially at the volume levels of an SRRI when its cranked.
  10. THX1123
    THX1123 Tele-Meister
    A part of NY that's far from NYC
    I've had good results with a Wampler Tumnus into a ZVex Channel 2 into a 5E3 circuit
  11. Cosmic Cowboy
    Cosmic Cowboy Tele-Meister
    New Mexico
    There is something to be said for having a second boost, not so much to color the tone, but to give more for punching a solo through.
  12. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    I run two boosts, but not to drive the amp. One (Xotic Super Clean) is in a loop with a compressor for clean leads. The other (Keeley Katana) is at the end of the chain, set modestly higher for dirty leads or to raise the volume when using lots of modulation or reverb.
    I don't really need that first boost, as the comp has a volume knob. But it sounds better with it. It cuts some of the highs and keeps the noise down.
    When I use both boosts, it's just to get the clean lead a little louder.
  13. Ringo
    Ringo Poster Extraordinaire
    Memphis TN
    I had a boutique boost pedal that had 4 different types of boost circuits, you could mix and match, there were some cool sounds but the more you boosted the noisier it got too.
  14. 65 Champ Amp
    The idea of stepping on a booster to punch a solo through makes me cringe.
    Especially with the insane amount of decibels on tap with some of these boosters. To paraphrase Warren Zevon, He’ll rip your ears out, Jim.
    I would much rather use it to make my amp sound like it’s working harder than it is, just leave the pedal on, and use my guitar volume knob.
    Jakeboy likes this.
  15. trxx
    trxx Tele-Afflicted
    Between reality and imagination
    I have used two, but one up front, the other in the effects loop. And the one in the effects loop was an eq, to have boosting and shaping. It sounded good, but it added too much hiss. It definitely pushed the amp into some good drive, but I wondered if it might have been bad for the amp long term, plus the hiss issue.
  16. jddub440
    jddub440 Tele-Holic
    Tacoma
    I rocked a couple LPB-1's into a cheapo practice amp and was having a blast getting those sorts of overdriven tones and occasional overloading bloomo_O
  17. Shango66
    Shango66 Friend of Leo's
    I usually have a boost at the end of my chain.
    my new FD 3 has an independent boost so I can boost from the front as well. I set them to give me a hair more.
  18. Bob Arbogast
    Bob Arbogast Tele-Afflicted Silver Supporter
    Lowell, Michigan USA
    At one time I think my dirt was:
    Flying Dragon-->Fat-Boost 2-->Fat-Boost 3
    All together it sounded great. Piece by piece the shadings were too subtle.
  19. Guitarteach
    My Fulldrive 3 in compcut mode is a clean boost into a very loud mildly dirty boost. Good with my JMP. The option to dial in a little dirt gives more options.
    it will all depend on headroom further down the chain and whether it sounds pleasant, compressed or adds proportional volume/gain. Can only try.
  20. scooteraz
    scooteraz Friend of Leo's
    Peoria, AZ
    Well, my favorite straight boost is a Zvex SHO, the single version. It is a great boost, very little coloring of the signal, just what you have, louder. The circuit is basically a 1960’s recording console gain stage, so stacking them is just overloading an input channel to a mixing board. Not my sound.
    However, if you want to suddenly crank up the input to an amp (or have a buffer at your board) that is the boost to use.
