Bluesblooded 2013 Challenge build: Dreamcaster
Discussion in '2013 TDPRI Tele Build Challenge' started by BluesBlooded, Jul 20, 2013.
  1. dave4567
    dave4567 Tele-Meister
    On my build I sanded until all the shiny spots were gone, but what do I know.:)
  2. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    That was what I thought, heard, read and so on. Would have loved to hear otherwise. Sure hope I have enough nitro on there to not sand through.
    Thanks Dave
  3. lookslikemeband
    lookslikemeband Tele-Holic
    CO - again
    In my opinion... those spots are so close to the edge I would do them with the next grit up, either 800 or 1000. They'll still come out, and you'll be safer from a sand-through.
  4. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    What is your next grit?
  5. BluesBlooded
    I did not mean the ones on the edge but the really small one in the middle of the body. I kept away from the edge on purpose.
    The shiny spots are the size of a needle tip.
    800, 1000 then finish with 1200
    Thanks guys, I appreciate the help.
  6. kwerk
    New Zealand
    Yep, I'd work at it now with the 800 for a bit, til they're almost gone, then move to the 1000 to get the last of it. 600 is pretty coarse if you're worried about creeping up on a sandthru.
  7. rockdog.
    rockdog. Tele-Meister
    Germany
    :eek: What the heck is a 'RockDog finish' ?? :lol:
    I'd suggest try to sand the shiny spots out, be very careful not to sand through the clear coats, and I bet when you're done with sanding and polishing it'll look killer! :cool:
  8. metecem
    metecem Friend of Leo's
    berlin,now in Istanbul
    It's a ridiculously shiny piece of wood covered in nitro. The legend says the Saints of Tone-a-loo schlepp the special water for the wetsanding from the highest mountains of Leoberg while the others grind marble pieces to dust which then get glued to backing paper with the saliva if the three horned goat and then use it as sanding paper.
    Told ya, it's crazy yet becoming an industry standard
  9. dazzaman
    dazzaman Tele-Afflicted
    Copenhagen, Denmark
    You will kick yourself if you still have some pinhead indentations in the final finish, but, PLEASE, don't sand through the clear. FWIW I would agree with what Kwerk says as the next step. Looking great so far.
  10. BluesBlooded
    Thanks Phil, I will start with the 800 grit and work them out.
    Thanks RockDog, I will try to remove them. If I do sand trough, then I'll put some more black on it, then nitro and let it cure.
    I'm almost there, I already have the marble dust and the three horned goat saliva. Got them from the bay;) Did not find the Leoberg mountain water yet. I'll have to use fiji bottled water. Hope it'll be close:rolleyes: Thanks Metecem!
    Thanks dazzaman. I will do my best not to sand through. I really want this one to shine. I'd rather kick myself because of a sand trough than having a sub par finish.
    Here I go wet sanding, I will keep you guys posted.
    Many thanks for all your precious help
  11. BluesBlooded
    After an hour of wet sanding at 800 grit
    So here how the top looks after an hour of 800 grit wet sanding. I would say that most of the pinheads are gone. The few ones remaining should disappear once I move up the grits.
    No sand through yet :D
  12. dave4567
    Looking great!
  13. BluesBlooded
    Thank you Dave. I'm getting there! Thanks to your advice and all the others here at TDPRI.
    So now 4 hours later, I've gone through 800 and 1000 grit.
    I switched direction sanding between grit to see my progress. Easier this way
    This is what it looks after 1000 grit
    Now going to my trusted kitchen table and moving to 1200 grit.
  14. BluesBlooded
    Body update
    First, I apologize to all the other challenger, I wish I had the time to go and see your last sprint and support you, but the clock is ticking here too! May you all finish in time.
    Got to use my buffer :D
    with medium compound
    getting a shine. I'm at that exact moment ECSTATIC!
    After an hour break I started the fine compound
    Inspecting my nose hair!
    Now a few reflection shots.
    a bit cloudy today
    removing some dust. Go away dust!
    Now I need to build a garage to work in this winter. Nice having an outside shop with a view, but that's only good 7 months
    Now, the neck
  15. BluesBlooded
    Neck
    Two nights ago I put the neck straight and let it sit overnight
    Last night, checked it again
    Marked the frets
    Sanded them down
    Crowning
    Dressing
    Sanding stick
    Final shine with 0000 steel wool
    Now this afternoon,
    Decal before I started sanding.
    Not a thick enough coat to blend the decal properly. I stopped there. It won't be perfect.
    Sanded down to 1000 grit
    and buffed
    Not too bad after all
    That's it for today folks! Still a lot to do tomorrow.
  16. bluepingu345
    bluepingu345 TDPRI Member
    England
    Looking great!
  17. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    Cool, the body is like mirror.:)
  18. kwerk
    New Zealand
    Wow, I want a buffer station. That is just killer.
  19. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Lynchburg Tennessee
    Me too! That looks fantastic.
  20. Allthesound
    Allthesound Tele-Afflicted
    Connecticut
    +2 that really transformed that finish! Sweet!!!!
