Blues Junior III reverb/volume issue
Discussion in 'Amp Tech Center' started by Danny87, Sep 23, 2016.
  1. Danny87
    Danny87 TDPRI Member
    United Kingdom
    Hi,
    I'm new here so please excuse me for asking such a noob question :(
    I've just purchased a fender blues junior III which rocks! Been playing through it with my squier classic vibe teles but I've noticed one little thing that is kinda irritating but could also be completely normal (I'm not that experienced when it comes to gear).
    Whenever I have the volume past 7, which is on verge of breakup, if I have the reverb on it produces kind of a distorted/vibration sound within the amp when I play certain notes or bends. I have tightened all screws, changed all the tubes, checked reverb tank but to no avail.
    Is it normal or is there something not quite right?
  2. elmoscafeo
    elmoscafeo Tele-Afflicted
    Chicago Suburbs
    Tightened all the screws?? On the reverb tank?? That'll make it worse. Reverb tanks should be loose and have rubber grommets installed to help isolate them between the reverb chassis and the amp. Sounds like you may have been getting some speaker vibration induced in to the reverb tank, causing the springs to oscillate. Loosen the screws on the reverb tank and try mounting the tank in a reverb tank bag. If you don't have one, try applying some weather stripping under the reverb tank edges to help isolate it from the amp cabinet.
    asnarski likes this.
  3. Danny87
    United Kingdom
    I have tightened all the screws around the cabinet, I have left the reverb tank screws loose. I will get a tank bag and see if that helps. Thanks
  4. vegie1
    vegie1 Tele-Meister
    GB
    I had the same issue, I put a sheet of bubble wrap under the tank.
    elmoscafeo likes this.
  5. Danny87
    United Kingdom
    Thanks for the tip dude!
  6. Danny87
    United Kingdom
    For anyone reading this with the same problem. I found out it was indeed the reverb tank springs oscillating. It is a ruby tubes 8EB2C1B tank. I tried the above to no avail so I decided to replace the tank with the MOD 8EB2C1B. I can now drive my amp with reverb without getting any of the noises mentioned and it actually is a much nicer verb. Problem solved!
  7. robrob
    United States
    Cool, congrats on fixing the reverb problem.
    Danny87 likes this.
  8. Thin69
    Thin69 Friend of Leo's
    Galveston, TX
    Great, congrats on getting the amp working properly!
    Danny87 likes this.
