Blues Jr Rev A Layout
Discussion in 'Amp Central Station' started by nathanh, Jun 6, 2017.
  1. nathanh
    nathanh Tele-Meister
    Bama
    I've been fiddling with the DIYLC app. Fun!
    My introduction to understanding amps was researching mods for my Blues Jr and studying the Billm (rest in peace bud) website and I remember really wanting a layout for these amps. I'm a visual learner and PCB's are hard to learn from above. I later found our friend @robrob's website and went to town. There I learned how to read schematics and a more in depth understanding. Still learning.
    Anyways here's my practice in reading a schematic. This is a Blues Junior Rev A with a Rob 5F6a style bias circuit and with no reverb channel. I've also got the schematic copied below. Help me find any mistakes?
  2. robrob
    United States
    The newest version of DIYLC (still free) allows you to rotate your tube sockets. Set 50 on the octal sockets and 315 on the 9-pin sockets and they line up the way we actually install them in the chassis. If you do this to an existing drawing you will have to manually move every lead to the correct pin.
    You can also set pots either shaft up or down--for example on your bias pot, if it is set shaft down (sicking out of the bottom of the chassis) it will properly give you a hotter bias as you turn the pot up (clockwise). If you mean it to have the shaft sticking up into the chassis then it's backwards and you'll get a cooler bias when turning the pot up.
    I don't see any errors on your layout, nice job.
  3. nathanh
    Bama
    Thanks Rob, I'll check my version of DIYLC and make the correction. On my first (and only) build I actually installed V2 turned the wrong way. Felt sheepish later.
    Now for the modded versions to come.
  4. nathanh
    Bama
    Updated. I noticed I also have my input jack inverted from how you use yours. Should be correct now.
    EDIT: messed up the NFB. Jesus Christ.
  5. nathanh
    Bama
    Take 4
  6. PaceAmps
    PaceAmps TDPRI Member Vendor Member
    Muscle Shoals, Alabama
    Is there a way to import an existing 5e9a layout into this program?
  7. robrob
    United States
    I don't know of a 5e9a DIY layout and I don't know of a way to import one from some other source.
  8. Mat
    Mat Tele-Meister
    Bumped to new post
