Blues Jr. hums w/ no input/volume @ 0 and sounds distorted when played at any volume
Discussion in 'Amp Tech Center' started by Quinn T Eskimo, Oct 17, 2020.
Tags:
  1. Quinn T Eskimo
    Quinn T Eskimo NEW MEMBER!
    Woodside ny
    BJ III blew fuse
    1. Replaced fuse, noticed crackling in power tube. Replaced power tubes. Now amp has crackling sound when played. Also humming sound at any volume and even with no input. Also resoldered all tube bases.
    2. Replaced preamp tubes. Problem unchanged.
    3. Replaced 4 large IC capacitors. Problem remains unchanged.
    4. Poking around board/tubes with chopstick has no affect.
    anyone have any other suggestions?
  2. JRapp
    JRapp Tele-Holic
    Phoenix, AZ
    1. remove Fender name plate with hydraulic jack
    2. discard amp in dumpster
    3. slide a real amp (not designed by Shane Nicholas) under the name plate
    TIM5150 likes this.
  3. edvard
    edvard Friend of Leo's
    Bremerton, WA
    If it blew a fuse, assume something shorted. Pull the tubes and check to make sure you are getting proper B+ and Heater voltages, as the transformer may have gone. Check for AC at the Plate connections, which might indicate your rectifier stage went kablooey; inspect diodes and power caps.
    Beyond that, I dunno.
  4. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. Great Britian.
    It would be useful to know if the hum is mains frequency or double mains frequency. That will at least tell us where the hum comes from.
    Check the screen grid resistors, replace R52 with 33k.
  5. Quinn T Eskimo
    Woodside ny
    Thanks for the replies. Based on my ability to try these recommendations (I’m basically a residential electrician with a multi-meter and soldering gun), I may have to have an amp tech look at this.
    I’m good at following directions if anyone can offer anything more specific (i.e. meter across these two points).
    Thank you
  6. Lowerleftcoast
    california
    For the hum. You have the amp apart. Make sure the grounds are attached to the chassis. The output jack doesn't appear to be grounded, for instance.
    Crackling:
    Make sure tubes pins/sockets are making good contact. Use deoxit and work tube in/out of socket.
    You have already re-flowed the solder on the socket terminals.
  7. 4wotitswurth
    4wotitswurth Tele-Meister
    I had a similar problem with mine. I’m not saying this is necessarily the case with yours, but after cleaning tube sockets and replacing tubes etc I finally swapped the tube board with this..
    https://reverb.com/item/10803881-fe...acement-tube-pcb-with-bias-test-points-by-mox
    might be a different version for your BJ3, but at least for me it solved all my problems. Basically the tracks on my tube board had burnt across with excess heat, my guess... like you, a guy with a fluke and a weller.... ;)
    saltyseadog and Quinn T Eskimo like this.
  8. saltyseadog
    saltyseadog Tele-Holic Silver Supporter
    Hartlepool, England
    Earlier this year I did a major mod to my green board BJr' adding one of these boards along with a new Hammond 1760F output transformer which made a huge difference to my amp. Over the years I had it twice into a tech with problems with the original tube board overheating and damaging connections. These boards are made differently and are much better than the Fender ones and a very helpful seller as well. Cannot talk any higher about these. Unsure whether this will fix the OP's amp but any BJr' owner should be aware of this simple to install mod.
