Blues Deluxe Reissue Problem
Discussion in 'Amp Central Station' started by gungnir, Jan 2, 2017.
  1. gungnir
    gungnir TDPRI Member
    Romania
    Hello, this is my first post around here. I don't know exactly if I'm posting in the right community, but I've seen that there have been before discussions so I said I'd give it a chance.
    I have a problem with my freshly bought amplifier, Fender Blues Deluxe Reissue.
    The sound itself is amazing but, on the clean channel, the master volume seems to have no effect whether it is at full 12 or at 0.(on the drive channel both the channel volume and the master work)
    By the channel volume I can get from very mellow perfectly clean tones to somehow cranked crunchy tones at around 12, but the master volume has no effect at all, no matter if I'm on any of the two inputs or if the bright switch is engaged.
    Please help me, I want to know if it's anything that I can fix at home or I need to find somebody with a steadier electronics luggage of knowledge.
    Thanks in advance and sorry for my bad English!
    All the best!
  2. Wally
    Iirc, the MV functions only in the Drive mode.
    clintj likes this.
  3. gungnir
    Romania
    Yes, that's right. Is it normal to do so?
  4. Alamo
    Alamo Doctor of Teleocity
    Berlin
    There's nothing to fix. the clean channel only reacts to the volume knob.
    except....I changed the volume chicken knob to a different colour, to not get confused in dim light.
    oh and welcome.
  5. Wally
    That is the way that amp works. It is designed this way so that you can drive the preamp hard in the Drive mode while keeping the output volume lower with the MVto balance with whatever volume you choose for the Clean mode. Fwiw, this is a single channel amp. Ime, a change to a lower gain tube in V1 helps in both the Clean and the Drive modes....5751 or a 12AY7. Also, these amps are usually biased to the cold side of things. Rebiasing can make a much better sound, IMHO.
    hrstrat57 and Alamo like this.
  6. gungnir
    Romania
    Thanks to both of you! You spared at least 50$ of my money(what it's worth to get my amp checked) and definetely put me back at ease.
    Thanks again! :D
    Wally and Alamo like this.
