Blown Power Transformer?
Discussion in 'Shock Brother's DIY Amps' started by HBamps, Oct 2, 2020.
  1. HBamps
    HBamps Tele-Meister
    Alameda, CA
    Im headed to the hardware store to get stuff for a lightbulb limiter!
    Funny, I have never even heard of one until yesterday! haha.
    BobbyZ likes this.
  2. charlie chitlin
    Kimberton
    I have a big 150 watt spotlight in mine.
    I spray painted it red because the damn thing had me seeing spots for 20 minutes!
    tubegeek and BobbyZ like this.
  3. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Feel bad we sent this guy out into the wild thinking he was gonna come home with an incandescent bulb. :cry:
  4. Nickfl
    Nickfl Friend of Leo's
    True, I would guess that was the thinking behind Fender using a champ power transformer in the original Princeton. However, those were also supposedly prone to failure in the Princeton, but apparently fine in the single ended amps.
    Lowerleftcoast likes this.
  5. Lowerleftcoast
    california
    The tube sellers will be stocking NOS incandescent bulbs soon. hah.
    And we will buy them.:rolleyes:
    BobbyZ, Wally and sds1 like this.
  6. tubeToaster
    tubeToaster TDPRI Member
    Brentwood,Tn.
    Is a variac the only alternative to a light bulb limiter ?
  7. King Fan
    Salt Lake City
    Apples and oranges; in my view, an LBL is cheap, readily available, and has one *primary* purpose -- to detect shorts while protecting the amp from them. A variac, set right, may limit short-circuit currents and damage, but doesn't AFAIK actually detect 'em. And it's not cheap or as readily available. OTOH it does have many more advanced functions an LBL doesn't.
    TLDR version; every amp builder needs an LBL; only a few really *need* a variac, and if they do, it's for other purposes.
    Nickfl, dan40, BobbyZ and 3 others like this.
  8. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Agree with @King Fan A LBL is a lot more useful than a veriac. A veriac changes voltage, a short at 50, 90 or a 120 volts is still a short and shorts are always bad.
    With the LBL a dead short just makes the bulb burn full bright, amps fuse doesn't blow and nothing starts smoking.
    The one or two times I used my veriac for firing up a new build or a rebuild, I put the LBL in line between it and the amp.
    Haven't used the veriac in years, really kind of unnecessary in my view.
    sds1, Nickfl, dan40 and 2 others like this.
  9. HBamps
    HBamps Tele-Meister
    Alameda, CA
    So I built a limiter (a kind of fun project on it's own) and tested the amp. With everything 120 VAC disconnected the lightbulb was glowing BRIGHT. From there I was pretty certain the PT was a goner. I had an old Hammond 269DX laying around so I figured I'd try that. It's a 275 / 275 secondary so I was prepared for a lower B+.
    Anyway, hooked it just the 120 VAC, lightbulb barely lit.
    Hooked up the rectifier, barely lit.
    Hooked up B+, lit a little on start up.
    Hooked up heaters, same.
    That all seems as it should and voltages are right in line with the Weber 350 on the plate of the 6V6.
    I don't know what happened to the weber PT but it's the 4th one I have had experience of blowing. Maybe now I'll get the lesson to stay away from their PTs....
  10. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Sorry about the PT but I feel so much better about where you ended up. That's crazy about all the blown weber PTs...
  11. Wally
    a meter will likely tell you what winding/s is/are problematic. Test the resistances of each winding...all primary and all secondary windings. Also, test each winding’s resistance to the frame of the transformer. If you find an open winding....infinite resistance....you have found a problem. If you find continuity between any of the secondaries or between any winding and the frame, you have found a problem.
    HBamps likes this.
