Blend Pot with Switch
Discussion in 'Other Guitars, other instruments' started by rosa, Jul 2, 2020.
  1. rosa
    rosa TDPRI Member
    washington dc
    I have a first act VW guitar with humbuckers and a 3 position pickup select switch. Its a nice guitar to experiment with. I was able to make a fuzz out of the onboard circuit.
    Anyways, I am trying to find a clean way to add a switch to convert the the hum buckers in to single coils.
    Would it be possible to use a blend pot instead of the 3 way switch, and use the type where you pull on the knob to ground the first coil of the humbuckers? In other words a blend pot and Single/double coil selector in one.
    Or would a switch with more positions be a better path?
    Thanks
