Blend control
Discussion in 'Burnt Fingers DIY Effects' started by FosterF, Dec 10, 2011.
  1. FosterF
    FosterF Tele-Meister
    I'm wanting to build an overdrive pedal with a knob to blend the clean signal back into the overdriven one. (Like the Sparkle Drive) Should I put the blend before or after the level control? I'll be putting a buffer in the clean signal that is being blended.
    Before the level control seems correct?
    Am I wrong?
    Thanks in advance!
    -Foster
  2. justin.ray
    justin.ray Tele-Meister
    Lindale, Texas
    The only schematics I've seen for a blend have tied in before the level knob.
  3. limbe
    limbe Tele-Afflicted
    Stockholm,Sweden
    I´m looking at an old digital reverb rack effect from where I am sitting.The last knob says "output".The one before that says "direct/reverb.It is as Justin says.Blend them first to get the right sound,then set the output level.
  4. FosterF
    Alright that makes sense!
    Should I include an effect level AND master level? (controls would be Gain, Tone, Effect Level, Clean Level, Master level)
    And do you have any of those schematics?
    Thanks!
  5. tjk3052
    tjk3052 Tele-Holic
    The wild wild midwest
    Found this schematic a while ago and thought it was interesting.
